Solve Brachistrone Problem: Find Path for Least Time Taken
  • Level: Graduate
  • Thread starter pardesi
8 replies · 8K views · last reply
pardesi
i have this doubt in the famous brachistrone problem
The Problem
we have to find the path [tex]y(x)[/tex] connecting two fixed points so that a body sliding along it under the influence of gravity only from rest should take the least possible?
The Proof
consider any length [tex]ds[/tex] along the path the time taken to cover it is [tex]\frac {ds}{v}[/tex] where [tex]v[/tex] is the speed of the body at that point then we have the toatal tiem taken to coevr the entire distance is [tex]T = \int_{1}^{2} \frac {ds}{v}[/tex]
now we have by conservation of energy [tex]v = \sqrt {2gy}[/tex]
thus [tex]T = \int_{1}^{2}\frac {ds}{\sqrt {2gy}}[/tex]
clearly [tex]y[/tex] is a function of [tex]s[/tex] also we have by the calculus of variations a standard resukt that if
[tex]I = \int_{x_{1}}^{x_{2}} f(\dot{y},y,x)dx[/tex] is an extremum then we must have [tex]\frac {d (\frac {\partial f}{\partial \dot{y}})}{dx} = \frac {\partial f}{\partial y}[/tex]
where [tex]y \equiv y(x)[/tex]
here similarly we have [tex]f[/tex] as [tex]\frac {1}{\sqrt {2gy}}[/tex] and [tex]s[/tex] as [tex]y[/tex] and if we proceed so we get absurd results instead
if we put [tex]ds = \sqrt {1 + \dot{y}^{2}}dx[/tex] and then apply the result we get the right answer
my doubt is why does the result fail to hold in the first case?
pardesi said:
..the speed of the body at that point then we have the toatal tiem taken to coevr the..
Have you tried using less coffee? :wink:
yeah sry for that i was at a library so had to hurrily type that
the corrected version "..the speed of the body at that point then we have the total time taken to cover the.."
I have been trying to learn this sort of thing on my own lately - please say if I am making mistakes or have misconceptions.
The absurd result you get in the first case is y(s) = 0 right?
First time through I get
[tex]\frac {\partial{F}}{\partial{y}} = -\frac {{y}^{-3/2}}{2 \sqrt {2g}}[/tex]
[tex]\frac {d}{ds} \frac {\partial{F}}{\partial{\dot{y}}} = \frac {d(0)}{ds} = 0[/tex]
since [tex]\dot {y}[/tex] does not appear in [tex]F; F = \frac {1}{\sqrt {2gy}}[/tex]
So it would appear that [tex]-\frac {{y}^{-3/2}}{2 \sqrt {2g}} = 0[/tex]
Giving [tex]y = 0[/tex]
Consider that F is simply [tex]F = \frac {1}{v}[/tex]
And that [tex]\frac {1}{v} = \frac {dt}{ds} = \frac {dy}{ds}\frac{dt}{dy} = {\dot{y}} \frac {dt}{dy}[/tex]
So we can write F in terms of [tex]\dot{y}[/tex]
then [tex]\frac {\partial{F}}{\partial{\dot{y}}} = \frac{dt}{dy}[/tex]
Clearly, the y-component velocity [tex]\frac{dy}{dt}[/tex] of the particle corresponds to a point along the curve it is falling.
Said differently, [tex]\frac{dy}{dt} = G(s)[/tex]
so [tex]\frac {\partial{F}}{\partial{\dot{y}}} = \frac {1}{G(s)}[/tex]
I am having difficulty thinking of what exactly [tex]G(s)[/tex] would be but it seems intuitive that
[tex]\frac {d}{ds} \frac {\partial{F}}{\partial{\dot{y}}} \neq 0[/tex]
so
[tex]-\frac {{y}^{-3/2}}{2 \sqrt {2g}} \neq 0[/tex]
and ultimately
[tex]y \neq 0[/tex]
It seems that introduction of x and it's relation to y eliminates all the convolution here.
Is this correct?
hi
the relation between ds, dx and dy :
[tex]ds = \sqrt{dy^2 + dx^2}[/tex]
which you wrote in your first post is needed in deriving brachistrome because we need an independent variable to calculate. And, with that in mind, variable s is not a good one because it depends on x and y (which one is dependent of another).
Moreover, ds is an elementary distance which particle traveled, you can't say that [tex]ds = dy[/tex] because there's a motion in x-axis also!
In the Euler's type of equation
[tex] I = \int_{x_{1}}^{x_{2}} f(\dot{y},y,x)dx[/tex]
[tex]\dot{y}(x), y(x)[/tex] must be a function of only x (and s is a function of x and y).
Since the variable s doesn't fit the Euler-Lagrange equation, you cannot assume that the solutions will fit to the connected condition:
[tex] \frac {d (\frac {\partial f}{\partial \dot{y}})}{dx} = \frac {\partial f}{\partial y}[/tex]
I don't fully understand the meaning of function G(s) in your derivation but i think that the problem with it was much earlier.
Let me try to be more thorough, so there is no confusion as to what I am doing.
We are minimizing an integral of the form
[tex]I = \int_{0}^{l} f(\dot{y}(s),y(s),s)ds[/tex]
by calculus of variations,
[tex]\frac {d (\frac {\partial F}{\partial \dot{y}})}{ds} = \frac {\partial F}{\partial y}[/tex]
Is true iff y(s) is such that it minimizes or maximizes [tex]I[/tex]
Specifically we are minimizing
[tex]T = \int_{0}^{l} \frac {ds}{v}[/tex]
which is the time taken by the particle in falling down the "ramp"
So [tex]F[/tex] in the context of the euler-lagrange equation is [tex]F = \frac{1}{v}[/tex]
No forces besides gravity are acting on the particle, therefore
it follows that, [tex]\frac {\partial{F}}{\partial{y}} = -\frac {{y}^{-3/2}}{2 \sqrt {2g}}[/tex]
which is one side of the euler-lagrange equation.
In solving for the other side we must see that [tex]F = \frac {1}{v} = \frac {dt}{ds} = \frac {dy}{ds}\frac{dt}{dy} = {\dot{y}} \frac {dt}{dy}[/tex]
so [tex]\frac {\partial{F}}{\partial{\dot{y}}} = \frac{dt}{dy}[/tex]
well, [tex]\frac{dt}{dy}[/tex] is simply [tex]\frac{1}{V_y}[/tex]
and [tex]V_y = \frac{ds}{dt}\frac{dy}{ds} = V \frac {d(y)}{ds} = \frac {1}{\sqrt {2gy}}\frac {d(y)}{ds}[/tex]
Then the other side of the euler-lagrange equation is [tex]\frac {d(\frac {1}{\sqrt {2gy}}\frac {d(y)}{ds})}{ds}[/tex]
And the solution to the brachistrone problem is
[tex]-\frac {{y}^{-3/2}}{2 \sqrt {2g}} = \frac {d(\frac {1}{\sqrt {2gy}}\frac {d(y)}{ds})}{ds}[/tex]
The introduction of x is not needed to solve the problem (although it seems to be necessary to get a nice looking result...)
I just spotted a mistake I made, this site doesn't appear to let me edit my posts so I'm forced to post another message...
The solution should be
[tex]-\frac {{y}^{-3/2}}{2 \sqrt {2g}} = \frac {d(\sqrt {2gy} \frac {1}{\frac {d(y)}{ds}})}{ds}[/tex]
hmm. Let's assume that's ok ;). But even if so, as i calculated, it seems that cycloid isn't the solution of this equation. I don't have time to write it now but have you checked it also? I checked the parametric formulas:
[tex]x = r(t - sin(t)), y = r(1- cos(t))[/tex]
