Solve Enjoyable Enigmas with Mr.E's Challenge
  • Thread starter Thread starter Enigman
1,043 replies · 224K views · last reply
Enigman is correct on the two he answered. Office Shredder, however, is not correct.
The probability it's a penny is real, because there is no other way of making a dollar with 50 coins.
He had no 50 cent coins, that's for sure also the number of pennies has to be a x5 or a x0
He could have 40 pennies, 8 nickels and 2 dimes - 4/5 = 80%
This is a difficult problem. I got this out of a MENSA puzzle book. Only 30% of MENSA members who took the test got this one right.
Your answer is, unfortunately, incorrect.
P(p=5)=1/10
P(p=10)=1/5
P(p=15)=3/5
P(p=20)=2/5
P(p=25)=1/2
P(p=45)=9/10
zoobyshoe said:
Billy had a coin purse with fifty coins, totaling exactly $1.00. Unfortunately, while counting them, he dropped one coin behind the radiator. What is the probability it was a penny?
For furriners:
$1.00
= 100 pennies
= 2 half dollars
= 4 quarters
= 10 dimes
= 20 nickels
(EDIT1-And cross posted with inotyce now...:mad:)
a+b+c+d+e=50
0.01a+0.5b+0.25c+0.1d+0.05e=1
a,b,c,d,e belong to N
to find: a/50
There can be more than one solution for two equations.
a has to have a units digit of either 5 or 0(relying only on trial and error now)
a=45,c=1, d=2, e=2;
a=30, e=20
ed2-ARGGGHHHH! who cares? inotyce just got it...add'em up ino and you got the answer...
And put it in spoilers!
:smile:
ed3-Okay just making sure the combinations are possible...
a=40,e=8,d=2;
a=35,nada don't get anything...
a=25,not here too...
a=20,...brain jam...:confused:
too much effort... for now I'm going with 1/3(45/50+30/50+40/50)
125/150=5/6...
The problem is poorly worded, I can't see any "hidden text" referring to something elusive. If there are different combinations of 50 coins to make 1 dollar then they can't ask what the probability of the lost coin being a penny is. This is not math anymore, this is linguistics 1o1 seems like.
On the contrary, I found it quite cleverly worded. Given the information we have been given we can't assume a specific combination of coins to be present and hence we have to account for all possible solutions- it was this particular thing according to me that the question was aimed at...after this its only simple logic and some trial and error or as a cryptologist would say brute force attack.
After all this is a problem for people in the MENSA, there is bound to be some clever deception in the wording...
-that is of course assuming my and inotyce's logic hold...
I got the same answer as Office Shredder. The book says this is wrong, due to the fact there is more than one combination of coins possible.
The authors of the book obviously believe you can. The answer they give as correct is the average of the probabilities of all the possible combinations.
I think the wording okay. It's this type of logic that is necessary to explore (in terms of information theory) when designing/analyzing digital communication systems. Digital communication systems involve things like your cell phone and WiFi.
One has to do things like calculate the probability of bit error without knowing a priori what the original bit pattern was or even without a priori knowledge of which bit (or bits) in the sequence is in error.
If the receiving unit already knew what the original bit pattern was, there wouldn't have been any need to transmit it over the communication channel in the first place.
[Edit: And by the way, not all permutations of the original bit patterns are possible due to parity bits, cyclic redundancy code (CRC) bits, or other bits added for error correction/detection. And any of those bits might be in error too. The point is the receiver knows a little a priori information about the original bit pattern, just not everything.]
Was I correct? Or was inotyce?
Maybe the space behind the radiator *only* big enough to hold a penny. A dime would fall through and the other coins are too big.
Therefore the chance of the coin being a penny is 100%.
:-p
For furriners:
$1.00
= 100 pennies
= 2 half dollars
= 4 quarters
= 10 dimes
= 20 nickels
I'm going to guess that the probability is 0.85 (or if you wish, "85%").
There are exactly two permutations that are possible.
(a) 2 dimes, 8 nickels, and 40 pennies.
(b) 1 quarter, 2 dimes, 2 nickels, 45 pennies.
No other combinations are possible.
Now we need to make the first assumption about a priori probabilities: it is equally likely for pennies to fall behind the radiator than it is for coins of other denominations. In other words, we neglect the size/weight characteristics of the coins that might otherwise keep quarters from falling behind the radiator while pennies easily drop through. If we were given other information about these probabilities we would have to modify everything following. But for now we assume that it is just as easy for a penny to fall behind the radiator as it is for any other type of coin. I just want to point out that this is an assumption I'm making.
We have the conditional probabilities, that
If (a), the probability that a penny fell behind the radiator is 0.8.
If (b), the probability that a penny fell behind the radiator is 0.9.
Next we need to make a second assumption about the a priori probabilities: (a) is equally likely as (b). This is an assumption I'm making. If we found that the Billy worked in the 25 cent gumball machine industry and had a high propensity to carry around quarters (more than other types of coins), it would change the probabilities from here on out. If there was shortage of nickels in circulation, it would affect the probabilities from here on out. There is a rarity of half-dollars for example, but fortunately a configuration involving a half-dollar is not possible. So I just want to point out that my "(a) is equally as probable as (b)" is merely an assumption I'm making here. If more information was given about the relative distribution of coins in circulation -- particularly applied to Billy's habits -- one could modify everything from here after.
Since (a) is equally probable as (b), final answer is 85 coins out of 100 coins, or 0.85.
(I'm sorry if somebody else guessed this first, but I honestly wasn't able to quite understand what some of the other guesses were.)
I think you said there was a 5/6 (8333...%) probability of it being a penny, and I think Intoyce said there was a 90% chance. If that's correct, the book says those are both wrong answers.
:-p
There could also be a gremlin behind the radiator turning every coin that falls there into an old, dry skittle.
Okay, I think collinsmark got it. I just checked my calculations and one of the cases was wrong...
(30 pennies and 20 nickels...have I mentioned I'm an idiot?)
Just for my edification, how did you arrive at the fact there was more than one possible combination, and that two combinations was the upper limit? (I assumed there must only be one possible combination and, as soon as I found it by trial-and-error, stopped and thought I had the answer. That, to me, was the trick part of this puzzle, that they passively allow you to assume there's probably only one combination.)
I was at the swap meet a couple weeks ago and saw a book titled something like, "238 Migraine-Inducing Classic Russian Math Puzzles." I didn't buy it because I figured I, personally, had no chance of solving any of them. Now I wish I had bought it because most of the purely mathematical enigmas posted here are way too easy for a lot of you. Maybe that seller will show up again sometime with that book.
a+b+c+d+e=50
to find: a/50
a-no. of pennies
and so on...
You have 2 equations and 5 variables so there's bound to be infinite solutions but then there's the constraint that numbers can only be positive integers less than 50. After that's just trial and error. When you have got till 40 pennies its obvious any more solutions can't be found(- I did a mistake and took the 30 penny case and messed up the sums 50 and 100...)
Code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace Coin_Behind_Radiator
    class Program
        static void Main(string[] args)
            int F, Q, D, N, P;
            double f = 0.5;
            double q = 0.25;
            double d = 0.1;
            double n = 0.05;
            double p = 0.01;
            for (F = 0; F < 51; F++)
                for (Q = 0; Q < 51; Q++)
                    for(D = 0; D < 51; D++)
                        for(N=0; N < 51; N++)
                            for (P = 0; P < 51; P++)
                                if ((f * F + q * Q + d * D + n * N + p * P == 1)
                                    && (F + Q + D + N + P == 50))
                                    // We got one. Print it out.
                                    Console.WriteLine(F + " Fifty-Cent pieces, "
                                        + Q + " Quarters, "
                                        + D + " Dimes, "
                                        + N + " Nickels "
                                        + P + " Pennies.");
            Console.WriteLine("Press any key to quit.");
            Console.ReadKey();
zoobyshoe said:
If Susan is 10, Arabella is 20, and Jim and Neal are both 5, but Richard is 10, how much is Jennifer by the same logic?
I tried letter-number exchange and syllable-number exchange...but I'm drawing a blank...
So, Baseball?
So, Baseball?
Not baseball. You're on the verge of a real "DOH!" moment, I think.
I'm also afraid I didn't understand either of the explanations.
that's cheating Collinsmark :cry: you can't use programming...and to think I didn't even use a pen and paper, typed all my thoughts out :approve:...but that probably lead me to my 30/20 mistake...to atone for that I am giving up my avatar.
Yes, I thought about that.
I got as far as proving that it is impossible to have a combination involving a half-dollar. That simplifies the math a little. It's pretty easy to prove that just by thinking about it. But then I just wrote the computer program; I figured, "ah, screw it." Here is what I was planning to do though in lieu of coding:
Now we have,
Quarters: Q
Dimes: D
Nickels: N
Pennies: P
(0.25)Q + (0.1)D + (0.05)N + (0.01)P = 1
Q + D + N + P = 50.
Then find valid combinations with Q = 1. Then prove that it's not possible if Q = 2 (or greater).
This will get you the first possible solution.
Then simplify the math more,
D + N + P = 50.
From here it's just brute force to find the other solution with the two dimes. (Once can solve the two simultaneous equations about 10 times to see if anything comes up, once for each value of D. It's a hit if N and P are both non-negative integers. [Edit: and you can reduce the number of times realizing that if D < 5 it's impossible to get sufficient coins. And also impossible to find a solution if D = 5, since things can't work out. That simplifies things a little more.]
Yes, I could have done that, but I figured coding would be easier. :smile:
EDIT-*crossed posts with collinsmark but hopefully between two of us we could clear it up better.
:smile:*
Ok, so let's begin with the variables:
  • a-no. of pennies b-no. of half-dollars c-no. of quarters d- no. of dimes e-no. of nickels
  • the equations that have to hold are:
  1. a+b+c+d+e=50
  2. 0.01a+0.5b+0.25c+0.1d+0.05e=1
  • But it is a general rule of math that to get unique values for all variables we need at least as many equations as there are variables- otherwise there are infinite solutions.
  • But we have the constraint that a.b.c.d.e are number of coins so they are whole numbers less than 50(total no. of coins)
  • After this we see that as lendav_rott said no. of pennies has to be non-zero otherwise we won't get anything near 50 coins.
  • then the no. of pennies has to be a multiple of 5 with units place 5 or 0 as otherwise we have no chance of getting $1 as sum- because all other values of coins in terms of pennies are multiples of 5.
  • After that its trial and error. 45 pennies and 40 pennies check out.
  • When we reach 35 we see that the no. of nickels can't cover it from then on to make 50. (nickels being the least valued after a penny)
  • So we can conclude that 45 and 40 pennies are the only case possible.
  • Assuming equal probability for both cases 1/2*45/50+1/2*40/50=0.85
Hope that clears things up a bit.
:smile:*
a+b+c+d+e=50
But it is a general rule of math that to get unique values for all variables we need at least as many equations as there are variables otherwise there are infinite solutions.
I will cogitate on this. Thanks.
DOH!
Homer inspires me...3*5=15...never thought about the special cases of letters aka vowels I even tried adding subtracting multiplying no. of letters and no. of syllables...
Replacing a penny increases your total amount of money by 4 cents.
50 pennies is 50 cents away from a $1, which isn't a number divisible by 4, so there has to be some dimes. Replacing 1 penny with 1 dime gets me to 59 cents, 41 cents obviously isn't divisible by 4, so...
Replacing 2 pennies with 2 dimes gets me 68 cents. 32 cents is divisible by 4, so I replace 8 more pennies with nickles to get $1.
No odd number of dimes is going to help me. Replacing 4 pennies with dimes gets me to 86 cents. 14 isn't divisible by 4.
I can go to 6, but that puts me over $1.00 before I even start with the nickles.
Replacing a penny with a quarter gets me to 74 cents. 26 cents isn't divisible by 4.
Going with a quarter and 1 dime gets me to an odd number.
Going with a quarter and 2 dimes gets me to 92 cents. Replacing two more of the pennies gets me to $1.00.
Going with a quarter and 4 dimes is over $1. With half a dollar I'm already at 99 cents.
So there's two solutions: 2 dimes, 8 nickles, and 40 pennies. 1 quarter, 2 dimes, 2 nickles, and 45 pennies.
Edit: Actually, I forgot about a solution with dimes and pennies, and no nickles. But since replacing a penny with a dime increases the amount by 9 and 50 isn't divisible by 9, I got lucky. There are no solutions with just dimes and pennies.
And likewise, there are no solutions with quarters and pennies only. And since replacing 1 penny with a quarter gets me to 74 and 26 isn't divisible by 9, there are no solutions with quarters, dimes, and pennies only.
