Flux of gradient field across sphere x²+y²+z²=a²
  • Thread starter Thread starter physics_197
    Sphere
7 replies · 2K views
physics_197
T(x,y,z) = -ln(x^2+y^2+z^2), F = -grad(T); S is the sphere x^2+y^2+z^2=a^2
Given:
F = (2/a^2) <x,y,z>
and the sphere x^2+y^2+z^2 = a^2
F (dot) n = (2/a^2) <x,y,z> (dot) (x/z,y/z,1)
In the end I get:
the double integral of: 2(a^2 - x^2 - y^2)^-0.5
Changing to polar coords I get:
2r / (a^2-r^2 ) drd(theta)
with limits: 0 < r < a and 0 < theta < 2pi
Once I solve it, I get an answer of: 4(pi)a, but the answer in the back is 8(pi)a
Is the answer in the back wrong? or did I make a mistake somewhere.
It seems to me that you assume that the normal vector n on the sphere is (x/z, y/z, 1) which is not true.
The normal vector has unit length.
Since any vector in the sphere has length a, the normal vector n is (x/a, y/a, z/a).
Does this answer your question?
When I try to use that, (x/a, y/a, z/a), I get an answer without 'a' in it.
So we have:
[tex]F \cdot n = \frac 2 {a^2} \vec x \cdot \frac 1 a \vec x[/tex]
And we have: [tex]\vec x \cdot \vec x = a^2[/tex]
So how does 'a' disappear?
I like Serena said:
So we have:
Yeh, I retried it and now I get 2(pi)a
When I converted to polar coords, I forgot about the rdrd(theta) part, so when i integrated wrt to r, I had (a-0) and that a canceled with the one on the bottom. When it should have been (a^2-0)
Apparently you're integrating over r and theta, but to integrate over the sphere surface, you need to integrate over theta and phi (at constant r=a).
Thank you very much, I got 8(pi)a now.
Is there anyway of checking the correct answer? Because I have another question similar to it but this one doesn't have the answer at the back.
Yes, this seems to me a problem that is leading to Gauss' Theorem, which is:
With div F = 6/a^2 and the volume of the sphere being 4/3 pi a^3, you can see that
[tex]\int \nabla \cdot F dV = \frac 6 {a^2} \int 1 dV = \frac 6 {a^2} \times \frac 4 3 \pi a^3 = 8 \pi a[/tex]
[EDIT]I've put in an extra step in the above formula[/EDIT]
