Solve Homework Questions on Point Sources & Mirrors
The discussion revolves around solving homework problems related to point sources and mirrors. For the first two problems, the user expresses confusion about light intensity equations, indicating they were told these would not be necessary. The third problem involves determining the minimum height of a mirror for a 67-inch person, which was approached using a ray diagram, although the user doubts the accuracy of their scaling. The fourth problem concerns a concave mirror with a focal length of 24.8 cm, where the user initially miscalculated the object position but later corrected it to find the correct answer. Overall, the user successfully resolved the mirror-related questions and no longer requires assistance.
Andy111
1) A 24 cd point source lamp and a 73 cd point source lamp cast equal illuminances on a wall. If the 24 cd lamp is 6.3m from the wall, how far from the wall is the 73 cd lamp? Answer in units of m.
2) Two lamps illuminate a screen equally. The first lamp has an intensity of 100 cd and is 6.7m from the screen. The second lamp is 7.7 m from the screen. What is the intensity of the second lamp? Answer in units of cd.
3) Determine the minimum height of a vertical flat mirror in which a person 67 in. in height can see his full image. Answer in units of in. (Hint: draw a ray diagram)
4)A concave mirror has a focal length of 24.8cm. Determin the object position for which the resulting image is upright and 4 times the size of the object. Answer in units of cm.
Focal length= \frac{Radius}{2}
\frac{1}{focal length} = \frac{1}{distance of object} + \frac{1}{distance of image}
magnification = \frac{-distance of image}{distance of object} = \frac{height of image}{height of object}
My teacher told us we wouldn't need to know the equations for light intensity, so I have no idea how to solve 1&2.
3) I drew the ray diagram like it said and found the area of mirror needed to see the image. But obviously it's not to scale, and I doubt I could measure it and scale it well enough to get an accurate answer, because the system we use to turn in homework likes exact answers that are at most +/-1% off.
4)I tried using this \frac{1}{focal length}=\frac{1}{distance of object}+\frac{1}{distance of image}
I knew that the distance of the image was 4 times the size of the object so i substituted distance of image with 4(distance of object). Crunching the numbers I got 31, which doesn't make sense because if the object is outside the focal point of a concave mirror, then the image will appear smaller, not larger. I think I messed up because it says the size is 4 times larger, which probably means height, not distance. But, I'm not sure what to do.
I found the equations for 1&2, so I don't need help with those anymore.
4. The magnification is related to heights and distances by:
<br /> M = \frac{h_i}{h_o}= \frac{-q}{p}<br />
where p is the object distance and q is the image distance. So here when you substitute you will have a minus sign (since the image is upright).
Thankyou so much. I got 18.6 substituting with -4 instead of 4, which was correct. I also got the 3rd question right. So I don't need any more help now.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
