Solve Impulse Response Homework - h(n), x(n), y(k)
The discussion revolves around a homework problem involving the impulse response of a discrete-time LTI (Linear Time Invariant) system, specifically focusing on how to find the output given an impulse response h(n) and an input x(n). The participants are exploring the method to determine the output y(k) through convolution.
  • Homework-related
  • One participant presents the impulse response h(n) and input x(n), expressing uncertainty about how to find the output y(k) and whether to use convolution or substitution.
  • Another participant explains that for a discrete time LTI system, the output is determined by the impulse response and suggests using the convolution sum to find the output.
  • There is a repeated emphasis on the convolution process as the method to determine the output, with a link provided for further reference.
  • Participants express confusion regarding the notation of y(k) instead of y(n), questioning the reason for this difference.
Participants generally agree on the use of convolution to find the output, but there is confusion and no consensus regarding the notation of y(k) versus y(n).
There are unresolved questions about the notation used for the output and the implications of using different symbols (k vs n). The discussion does not clarify the specific steps involved in the convolution process or the assumptions behind the notation.
Students or individuals studying discrete-time systems, convolution, or LTI systems may find this discussion relevant.
maearnie
I have an impulse response h(n)=e^(0.1n)*[u(n)-u(n-8)] and an input x(n)={0,1,2,3,0}, how do I find the output y(k)?
[/B]
i don't even know how to solve. should i try convolution or should i substitute the values of x(n) in h(n). and idk why its y(k) instead of y(n) you don't need to put the exact solution. you just need to explain what i need to do. thanks :)[/B]
For a discrete time LTI (Linear Time Inviariant) system, the output is completely determined by the output and the impulse response, which is the response to an impulse funtion (often called delta function). d[n] with d[0] =1 and d[x] = 0 if x<>0.
if you know the response to d[n], you know the response to d[n-t], and any input signal is a linear combination of impulse functions with different time shifts.
The way to determine this is the convolution sum. See here for example:
http://www.eecg.toronto.edu/~ahouse/mirror/engi7824/course_notes_7824_part6.pdf
Thanks for your response!
So i just need to convolve x(n) and h(n)? and the answer is y(n)? how will it become y(k) tho?
Sorry, I have no idea why they use y[k] and not y[n].
  • · Replies 17 ·
