Solve Lagrange Multipliers Problem w/ e^(9x) - Find (a,b)
ajkess1994
I have been stumped on this problem and I am probably overthinking it as usual. The problem deals with the Lagrange Multipliers:
Use Lagrange multipliers to find the point (a,b) on the graph of y=e^(9x), where the value (a,b) is as small as possible.
I have found the gradient for both when it's set up as [e^(9x) - y = 0], but now I don't know what to do from here. Would someone please be available to help me?
The objective function is "the value (a,b)" which I interpret to mean the distance from the origin to a point on the curve, and we can use the square of this distance for our objective:
$$f(x,y)=x^2+y^2$$
Subject to the constraint:
$$g(x,y)=e^{9x}-y=0$$
Using Lagrange, we obtain the system:
$$2x=\lambda\left(9e^{9x}\right)$$
$$2y=\lambda(-1)$$
This system implies:
$$\frac{2x}{9e^{9x}}=-2y$$
Or:
$$y=-\frac{x}{9e^{9x}}$$
Now, plugging this into the constraint yields:
$$e^{9x}+\frac{x}{9e^{9x}}=0$$
Or:
$$9e^{18x}+x=0$$
Using a numeric root finding method, we find:
$$x\approx-0.20902833541170100144$$
And so:
$$y\approx0.15239872243985548342$$
We then compute:
$$f(-0.20902833541170100144,0.15239872243985548342)=0.06691821560628668613644254416134077697$$
To ensure we have a minimum, we can use another point on the constraint, such as \((0,1)\), and we find:
$$f(0,1)=1$$
Thus, we may state:
$$f_{\min}\approx0.06691821560628668613644254416134077697$$
Here is a diagram of the solution:
  • Graph of the curve y = e^(9x) in red, joined to a green straight segment from the labelled point (a,b) down to the origin region; axes run from -0.4 to 0 horizontally and 0 to 0.3 vertically.
Thank you for helping me with this problem, enjoy the rest of Veteran's Day
