Solve Limit: $$\lim_{x\to0} \frac{sin(\pi(Cos^2(x)))}{\pi(Cos^2(x))}$$
  • Thread starter Thread starter Nipuna Weerasekara
    Limits
The limit $$\lim_{x\to0} \frac{sin(\pi(Cos^2(x)))}{\pi(Cos^2(x))}$$ evaluates to 0. This conclusion is reached by recognizing that as x approaches 0, the expression simplifies to 0/1, which is valid and results in 0. The discussion also addresses a related limit, $$\lim_{x\to0} \frac{sin(\pi(Cos^2(x)))}{x^2}$$, which can be solved without using L'Hôpital's rule by transforming the sine function and applying the limit properties of sine and cosine.
  • Understanding of limits in calculus
  • Familiarity with trigonometric functions, specifically sine and cosine
  • Knowledge of limit properties and the behavior of functions as they approach zero
  • Ability to manipulate algebraic expressions involving trigonometric identities
  • Study the application of Taylor series expansions for sine and cosine functions
  • Learn about the Squeeze Theorem and its use in evaluating limits
  • Explore advanced limit techniques, including the epsilon-delta definition of limits
  • Investigate the implications of L'Hôpital's rule and scenarios where it cannot be applied
Students studying calculus, particularly those focusing on limits and trigonometric functions, as well as educators seeking to explain limit evaluation techniques without L'Hôpital's rule.
Nipuna Weerasekara
Solve the following limit.
$$\lim_{x\to0} \space \frac {sin(\pi (Cos ^2 (x)))}{\pi (Cos ^2 (x))}$$
When I plug ##x\to 0 ## into the limit, I get 0/1... Then what can I do? See here I can't even apply L'Hopital's law... Please help!
Here I see the answer is 0 obviously... But I need to plug this result into another limit question. Which is the real challenge here...
For further guidance,
$$ \lim_{x\to0}\space \frac {sin(\pi (Cos ^2 (x)))}{x^2}$$
This is the limit question... The challenge is to get the answer to this limit by without using the L'Hopital's law...
Actually the real question here is to solve the limits question ##\lim_{x\to0}\space \frac {sin(\pi (Cos ^2 (x)))}{x^2}## without using L'Hopital's law...
Found the answer!
Just an easy fix... ##\;\sin(\pi\cos^2x)=\sin(\pi-\pi\sin^2x)=\sin(\pi\sin^2x)##
The answer is ##\pi##
The form 0/1 is perfectly OK; it just gives you 0. The only thing that is forbidden is dividing by 0; dividing 0 by something else nonzero is absolutely allowed, and always gives 0.
If your original question was not the one you were interested in, why did you pose it?
Anyway, if you are not allowed to use l'Hospital's rule, what ARE you allowed to use?
Note added in edit: posts #3 and #4 did not appear on my screen until after I submitted this response.
This is not a case whether you are allowed to use the L'Hopital law or not... It is a challenge where you cannot use it. Hence the question gets tricky...
The following shows the method to solve the limit without using the law.
##\lim_{x\to0}\space \frac {\sin(\pi\sin^2x)}{x^2}##
##\lim_{x\to0}\space \frac {\sin(\pi\sin^2x)}{x^2 (\pi\sin^2x)}{(\pi\sin^2x)}##
##x \to 0 \space ## then ## \space \pi \sin^2x \to 0##
##\lim_{\pi \sin^2x \to 0} \space \frac {Sin(\pi \sin^2x)}{\pi \sin^2x} \space \lim_{x\to 0}\space \frac {\pi\sin^2x}{x^2}##
## (1) \space. \space \lim_{x\to0}\space \frac {\pi\sin^2x}{x^2}##
##\pi \space \lim_{x\to0}\space \frac {\sin^2x}{x^2}##
##\pi \space .\space (1)##
##\pi##
  • · Replies 25 ·
  • · Replies 25 ·
  • · Replies 24 ·
