Solve ODE by Substitution: Find General Solution
thereddevils
By means of substitution x=X+1, y=Y+2 ,shwo that the equation dy/dx=(2x-y)/(x+2y+5) can be reduced to dY/dX=(2X-Y)/(X+2Y).Hence, find the general solution of the given equation.
The first part is quite simple to prove.
Second part,
since its a homogenous differential equation, i would use the substitution Y=vX here.
v+X(dv/dX)=(2X-vX)/(2vX+X)
[tex]-\frac{1}{2}\int \frac{4v+2}{2v^2+2v+2} dv=\int \frac{1}{X} dx[/tex]
ln |2v^2+2v+2|=-2ln |X|-c
then v=Y/X
ln |(2Y^2)/X^2+2Y/X+2|=-2ln |X|-c'
Then substitute back again from the first part,
the solution is
ln |2(y-2)^2/(x-1)^2+2(y-2)/(x-1)+2|=-2ln |x-1|-c'
AM i correct?
check this again because i got
[tex]-\frac{1}{2}\int \frac{4v+2}{2v^2+2v-2} dv=\int \frac{1}{X} dX[/tex]
ok thanks ,how bout the rest?
then v=Y/X
hmm, why do you change c to c' ?
and, others correct if I'm not wrong.
p/s: don't forget change the negative sign, :biggrin:
oh, maybe its not necessary. I multiplied both sides with 2 so c is now 2c and c'=2c
Is it ok to not change? Would it affect the equation?
You did the right thing even though c and c' are arbitrary constants.
yea, but you already multiply both side
"ln |2v^2+2v+2|=-2ln |X|-c
then v=Y/X
ln |(2Y^2)/X^2+2Y/X+2|=-2ln |X|-c' "
and you didn't multiplied here, correct me if I'm wrong
