Solve Orthogonal Projection for x+2y+z=12
  • Thread starter Thread starter ravicplk
    Projection
ravicplk
please can u do this sum for me...really urgent situation
find the equation of the orthogonal projection of the line x+1/1 = 2y/-1 = z+1/2 on the plane x+2y+z=12
thanks in advance
pleaaaaase help me guys!1
is there anyone who can do this
You probably made a mistake putting this in the "Topology and geometry" section!
The plane x+ 2y+ z= 12 has <1, 2, 1> as a normal vector. The line x+1/1 = 2y/-1 = z+1/2, which, setting each fraction equal to t, is the same as the parametric equations x+ t- 1, y= -(1/2)t, z= t- 1/2 have directional vector <1, -1/2, 1>. The projection of that vector onto <1, 2, 1> has length
\frac{&lt;1,-1/2, 1&gt;\cdot&lt;1, 2, 1&gt;}{||&lt;1, 2,1||}= \frac{1}{\sqrt{6}}
so the vector projection of <1, -1/2, 1> on <1, 2, 1> is that times a unit vector in the direction of <1, 2, 1>, \sqrt{6}&lt;1, 2, 1&gt;, and so is <1/6, -1/3, 1/6>. The projection of the vector onto the plane is <1, -1/2, 1>- <1/6, -1/3, 1/6>= <5/6, -5/6, 5/6>. That is, the parametric equations of the line are x= (5/6)t+ x_0, y= -(5/6)t+ y_0, z= (5/6)t+ z_0 where (x_0, y_0, z_0) is a single point on that projection. Putting the parametric equations of the line for x, y, and z in the plane, it see that the line intersects the plane when t= 27/2 so x= 25/2, y= -27/4, z= 26/2= 13 is a point on the plane and line and therefore on the projection of the plane into the line.
I am going to move this to the Calculus and Beyond Homework section.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
