Solve partial derivatives from a table
The discussion focuses on calculating partial derivatives related to the area, perimeter, and diagonal of a rectangle using analytical geometry. A table of known partial derivatives is provided, which includes relationships between area, length, breadth, and perimeter. One participant derived a specific partial derivative, ({\frac{\partial a}{\partial L}})d, using the product rule and requested confirmation of their method. Another participant confirmed the correctness of the derived expression but noted it was not listed in the provided table. The conversation emphasizes the importance of using both direct methods and the provided table for solving partial derivative problems.
noob314
Let a represent the area, p the perimeter, d the diagonal, b the breadth, and L the length of a rectangle. One can easily write down from analytical geometry all the various relationships between the above variables, and from these obtain directly a variety of partial differential quantities.
Thus, a = bL
hence ({\frac{\partial a}{\partial b}})L = L, ({\frac{\partial a}{\partial L}})b = b, and so on, in this way a complete family of partial differentials could be evaluated. Alternatively, however, one partial differential can be obtained from another through the use of the various rules given above.
The following table of partial differentials is given.
({\frac{\partial L}{\partial b}})d = -(b/L)
({\frac{\partial p}{\partial b}})L = 2
({\frac{\partial d}{\partial b}})L = (b/d)
({\frac{\partial L}{\partial b}})p = -1
In the following problems you are asked to find the stated partial derivative first by the direct method, and then by using only the partial derivatives given in the table above, plus the various rules for interconverting derivatives.
1. Find ({\frac{\partial a}{\partial L}})d
I'm not going to type all my work out, but basically what I did was form an equation where the 3 variables are used and what I ended up with is
a = (d2-L2)1/2L
and taking the partial derivative of that, holding d as a constant and using the product rule, I end up with
\frac{d^2 - 2L^2}{\sqrt{d^2 - L^2}}
Can someone confirm if what I did was correct? What I need help on is how to use the table to solve the problem, so if someone can give me a few hints on how to begin, it would be much appreciated.
a = (d2-L2)1/2L
What you have found is indeed, \displaystyle \left({\frac{\partial a}{\partial L}}\right)_{\!d}\,, although I didn't see that in the table.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
