Solve Physics Problem: 3000kg Space Capsule
  • Thread starter Thread starter bondgirl007
    Physics Space
A 3000kg space capsule traveling at 200m/s fires a 25kg projectile at 2000m/s perpendicular to its motion. The momentum conservation equation is applied, leading to a calculated speed of 1833.3m/s for the capsule after firing. The user expresses confusion about whether to use Pythagorean theorem for further calculations regarding the angle of direction change. Clarification on the correct approach to find the angle and final speed is requested. The discussion highlights the challenges of applying momentum principles in physics problems.
bondgirl007
A 3000kg space capsule is traveling with a velocity of 200m/s. In an effort to alter its course, it fires a 25.0 kg projecticle perpendicular to its original direction of motion at a speed of 2000 m/s. What is the speed of the capsule and by what angle has its direction changed.
* my teacher said assume mass stays the same*
P = mv
m1v1 + m2v2 = m1v1' + m2v2'
M = m1 + m2
V = combined velocity
MV = m1v1' + m2v2'
(3000)(200) = (3000)(v1') + (25)(2000)
v1' = 1833.3
Is this right so far? I'm very confused and am not sure if I should be using Pythagoras to find it or what?
Can anyone please help me out? I've been stuck on this question for over half an hour. :(
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
