Point charge suspended between capacitor plates at 22° deflection angle
7 replies · 9K views
waleye262
A point charge of mass 0.069 kg and charge q = +5.89 µC is suspended by a thread between the vertical parallel plates of a parallel-plate capacitor.
If the angle of deflection is 22°, and the separation between the plates is 0.025 m, what is the potential difference between the plates?
U = .5C*V^2
I know the left has a higher potential energy because the mass is attracted toward the right?
U = .5C*V^2
Welcome to PF,
If the charge is displaced to the right, then the left would indeed be at a higher potential.
Can you start by determining the tension in the string?
The tension of the string is m*g= .68
I am still lost at how to find the the force that attracts it to the side.
would it be 5.89E-6 cos 22?
That would be correct if the string was hanging vertically, but that isn't the case is it?
no its not hanging vertically so mg=cos22?
I am sort of lost...
You're getting closer:
[tex]T\cos22 = mg[/tex]
Now since the mass is in equilibrium, what can you say about the horizontal forces acting on the mass?
alright so the force acting on the mass is the same as the tension force which is 0.729.
so would you use F=q(v/x)?
Remember that you want the horizontal component of the force, not the vertical.
