Solve second order diff eq with substitution
Asphyxiated
Solve:
[tex]xy''+2y'=12x^{2}[/tex]
with
[tex]u=y'[/tex]
if you have:
[tex]y'+P(x)y=Q(x)[/tex]
then your integrating factor is:
[tex]I(x)=e^{\int P(x) dx}[/tex]
The only reason I was able to solve this is because I stumbled upon a similar post here but instead of pulling up a thread from over a year ago i decided to post my specific question.
So if:
[tex]xy''+2y'=12x^{2} \hookrightarrow y''+\frac{2y'}{x}=12x[/tex]
and
[tex]y'=u \hookrightarrow y''=u\frac{du}{dy}[/tex]
I do not understand why y'' is equal to this. The way I read y'' is d2y/dx2 so why is it u*du/dy as the derivative on the right side and not d/dx? And! why is the derivative of u with respect to y u*du/dy and not just du/dy.
Maybe I have just forgotten something simple from differential calculus but I can't make sense of it on my own. I am not claiming that what is written in TeX above is wrong because the problem seems to work out, I just don't know why that is the way to do it.
Anyway, if we make the substitution:
[tex]u\frac{du}{dy}+\frac{2u}{x}=12x[/tex]
then
[tex]I(x)=e^{\int \frac {2}{x} dx} = e^{2 ln|x|}=x^{2}[/tex]
then multiply both sides by I(x):
[tex]x^{2}u\frac{du}{dy}+2xu=12x^{3}[/tex]
which is:
[tex]\frac {d}{dx} (ux^{2})=12x^{3}[/tex]
[tex]ux^{2}=\int 12x^{3} dx =3x^{4}+C_{1}[/tex]
[tex]u=3x^{2}+ \frac{C_{1}}{x^{2}}[/tex]
[tex]\frac {dy}{dx}=3x^{2} + \frac {C_{1}}{x^{2}}[/tex]
[tex]y= \int 3x^{2}+\frac{C_{1}}{x^{2}}dx = x^{3}-\frac{C_{1}}{x}+C_{2}[/tex]
if that is right please tell me why. I just followed by example from someone elses work.
That's just the chain rule.
[tex]y'' = \frac{du}{dx} = \frac{du}{dy}\frac{dy}{dx} = u\frac{du}{dy}[/tex]
I'm not sure why you'd do it that way, though. You could simply write
[tex]x u' + 2 u = 12x^2[/tex]
and solve it with the same integrating factor without the unnecessary complication of invoking the chain rule.
oh haha alright. I guess I was confused by the substitution of y'=u again for some reason.
Thanks for the reminder on that!
So I assume this is a correct solution? It's an even problem so I can't look it up.
I didn't see anything obviously wrong, but I didn't look that closely either. You can always check your answer by plugging it back into the original differential equation to see if it's satisfied.
