Solve Your Tennis Racket Problem with a Geometric Approach
  • Thread starter Thread starter IamVector
    Kinematics Tennis
The discussion focuses on utilizing a geometric approach to solve a tennis racket problem involving elastic collisions. Participants emphasize the importance of symmetry in analyzing arrival and departure trajectories, although one contributor clarifies that the problem is not an elastic collision in the traditional sense but rather in the racket frame. A geometric method is proposed, involving the decomposition of velocity vectors into parallel and perpendicular components, and the construction of a right trapezoid to visualize the relationships between these components. The discussion highlights the complexity of the geometric approach compared to algebraic methods.
  • Understanding of elastic collisions in physics
  • Familiarity with vector decomposition
  • Knowledge of geometric shapes, specifically trapezoids
  • Basic algebra for velocity calculations
  • Study the principles of elastic collisions in different reference frames
  • Learn about vector decomposition techniques in physics
  • Explore the properties of trapezoids and their applications in geometry
  • Investigate the relationship between geometry and physics in motion analysis
Physics students, educators, and anyone interested in applying geometric methods to solve problems related to motion and collisions in sports contexts.
IamVector
A tennis ball falls at velocity v onto a heavy racket
and bounces back elastically. What does the racket’s velocity
u have to be to make the ball bounce back at a right angle to
its initial trajectory and not start spinning if it did not spin
before the bounce? What is the angle β between ⃗u and the
normal of the racket’s plane, if the corresponding angle for ⃗v is α?
take one of the axes (say x) to be
perpendicular to the racket’s plane and the other one
(y) parallel to it. Absence of rotation means that the y-
components of the ball’s and racket’s velocities are equal
Is there any geometric approach??
Symmetry may be a fruitful approach. The arrival and departure trajectories should be similar.
got u = v/2 cos α by algebraic approach and the angle. didn't got the geometric approach I think it will be easy by geometric approach.
IamVector said:
got u = v/2 cos α by algebraic approach and the angle? didn't got the geometric approach I think it will be easy by geometric approach.
Never mind. I misunderstood the problem. It's not an elastic collision per se. It's an elastic collision in the racket frame. Which means that in the ground frame, there is no symmetry to exploit.
I saw the hint by geometric approach it says :
Geometric approach: draw a right trapezoid as follows:
we decompose ⃗v into parallel and perpendicular compon-
ents, ⃗v = ⃗vx + ⃗vy; let us mark points A, B and C so that
AB⃗ = ⃗vx and BC⃗ = ⃗vy (then, AC⃗ = ⃗v). Next we mark
points D, E and F so that CD⃗ = ⃗v ′
y = ⃗vy, DE⃗ = −⃗vx,
and EF⃗ = 2⃗ux; then, CF⃗ = ⃗v ′
y − ⃗vx + 2⃗ux ≡ ⃗v ′ and
AF⃗ = 2⃗vy + 2⃗ux ≡ 2⃗u. Due to the problem conditions,
∠ACF = 90◦
. Let us also mark point G as the centre of
AF; then, GC is both the median of the right trapezoid
ABDF (and hence, parallel to AB and the x-axis), and
the median of the triangle ACF. What is left to do, is ex-
pressing the hypotenuse of △ACF in terms of v = |AC|I found this very tricky to understand but it is considered to be more easy than algebraic one so please help.
so what we can use??
11K
