What is the best solvent for removing bentonite clay?
  • Thread starter Thread starter cseal
    Clay Solvent
The best solvent for removing sodium bentonite clay is not water, as it can become overly hydrated. Instead, using solvents such as vinegar or isopropyl alcohol is recommended for effective removal. Dehydrating the bentonite with heat prior to applying these solvents can enhance the removal process. Proper techniques must be employed to ensure complete dissolution, especially on porous surfaces.
  • Understanding of sodium bentonite properties
  • Familiarity with solvent types and their applications
  • Knowledge of surface treatment techniques
  • Basic skills in handling and applying chemical solvents safely
  • Research the effectiveness of vinegar as a solvent for sodium bentonite removal
  • Learn about the application of isopropyl alcohol for clay dissolution
  • Investigate methods for dehydrating bentonite before solvent application
  • Explore surface cleaning techniques for porous materials
This discussion is beneficial for contractors, DIY enthusiasts, and anyone involved in construction or maintenance who needs to remove sodium bentonite from surfaces.
cseal
Hello,
Can anyone recommend a good solvent for sodium bentonite? I have used it as a sealant, and I need to remove it. Would it be better to dehydrate it with heat before trying to dissolve it?
Chemistry news on Phys.org
Thanks for the reply. I have bentonite on a porous surface, and I wish to remove it. I have already washed the surface, but there is still a layer of bentonite. Bentonite can become very hydrated, so I need to use a solvent other than water.
