Solving 0.012M/(d-x)^2=M/x^2 for x
  • Thread starter Thread starter thomasrules
12 replies · 2K views
thomasrules
For some reason i can't solve for x:
I have M value: (5.98)(10)^24
d is: (3.84)(10)^5
i started with cross multiplying:
0.012Mx^2=M(d-x)^2
0.012Mx^2=M(d^2-2dx+x^2)
then i divided both sides by the left side and crossed out M.
From there I don't know what to do
After you divided both sides by M and then divided both sides by .012, you should have wound up with:
[tex]x^2=\frac{d^2-2dx+x^2}{.012}[/tex]
Split the right side up into three fractions:
[tex]x^2=\frac{d^2}{.012}-\frac{2dx}{.012}+\frac{x^2}{.012}[/tex]
Substitute in your value for d. That should leave you with something you can work with.
Actually, I wouldn't divide both sides by 0.012, just because I don't like fractions!
0.012x2= d2- 2dx+ x2 is the same as (subtract 0.012x2 from both sides)
0.988x2- 2dx+ d2= 0.
With d= 3.85 x 105, d2= 1.48225 x 1011 so your equation is
0.988x2- (7.7 x 105)x+ 1.48225 x 1011= 0.
You can solve that with the quadratic formula.
does d in this case stand for difference like in calculus or is it just any other variable?
By,the looks of it,it's a dimensionful number...
Daniel.
PS.Got it,it's the mean distance Earth-Moon and M is the Earth's mass... :-p :approve: And it's in Km.
couldnt you first divde M on both sides and then find the square root??
as in
[tex]\frac{0.012M}{(d-x)^2} = \frac{M}{x^2}[/tex]
which then gives
[tex]\frac{0.012}{(d-x)^2} = \frac{1}{x^2}[/tex]
and then find the square rooton both sides
[tex]\frac{\sqrt{0.012}}{d-x} = \frac{1}{x}[/tex]
then cross multiply and solve without need for a quadratic??
I'm sorry,but it doesn't work that way.You need to consider the modulus when extracting sqrt,which would complicate the problem...
Daniel.
see i think it's this,
cross multiply,
x^2/(d-x)^2=M/0.012M
x/(d-x)={1/0.012}^1/2 (that is sq root)
x/(d-x)=9.13
dividing the numerator & denominator by x
1/{(d/x) - 1}=9.13
{(d/x) - 1}=1/9.13
=0.11
(d/x)=1+.11
=1.11
since,d is: (3.84)(10)^5,we have
x=d/1.11
=(3.84)(10)^5/1.11
=345,945.95 units
cross multiply,
THAT IS DEVIOUS...U should have a [tex]\pm[/tex] sign...
Daniel.
if its correct please tell me. :smile:
I thought i put in a very obvious way... :-p It's wrong.By inappropriately extracting square root,u lost one (possibly viable) solution.
Daniel.
