Solving (1/2)y'' + y^2 = 1: How to Attack?
  • Context: Graduate
  • Thread starter Thread starter Adeimantus
The discussion revolves around the differential equation (1/2)y'' + y^2 = 1, which participants are attempting to solve in the context of modeling the trajectory of a ball under constant gravitational acceleration and quadratic drag. The conversation explores various methods for finding approximate solutions, including considerations for different ranges of x.
  • One participant suggests approximating the equation for small x as (1/2)y'' + y^2 = 0, proposing y = -3/x^2 as a solution, but expresses uncertainty about further approximations.
  • Another participant recommends multiplying through by y' to transform the equation into a first-order differential equation, but later acknowledges confusion regarding the resulting integral.
  • Concerns are raised about the integral \(\int\frac{dy}{\sqrt{c+y-\frac{y^3}{3}}}\), with one participant suggesting it appears to be an elliptic integral, which generally cannot be expressed in terms of elementary functions.
  • A participant corrects their earlier equation to include a missing minus sign, leading to a new equation: \(\frac{1}{2}y'' + 2y^{\frac{1}{2}}y' + y^2 = 1\).
  • Another participant introduces a substitution method involving v(y) = y'(x(y)), leading to a first-order differential equation that may be easier to solve.
  • One participant mentions finding a solution y = tanh²(x-x₀) through guessing, relating it to a specific case of a ball falling straight down under quadratic drag.
  • There is a discussion about the challenges of finding a general solution for non-linear differential equations and whether there are methods to determine the number of solutions.
Participants express a variety of methods and approaches to tackle the differential equation, with no clear consensus on a single solution or method. Some participants agree on the complexity of the integral involved, while others propose different strategies without resolving the overall question.
Participants note the difficulty of integrating certain forms and the implications of elliptic integrals, which may limit the ability to express solutions in elementary terms. There is also mention of specific cases that may simplify the problem, but these do not lead to a general solution.
This discussion may be of interest to those studying differential equations, particularly in the context of physics applications involving motion under drag forces, as well as those exploring methods for solving non-linear equations.
Adeimantus
How would you attack this equation?
(1/2)y'' + y^2 = 1
I'm trying to find an approximate solution for the trajectory of a ball acted on by constant gravity acceleration and quadratic drag (proportional to the speed squared), and it turns out the speed squared satisfies an equation that is equivalent to this one after non-dimensionalizing. Any kind of solution would be nice, whether it is good for large x, small x, or whatever.
I was thinking that for x << 1, the equation would be approximately (1/2)y'' + y^2 = 0, in which case y = -3/x^2 is a solution. But then I don't know how to proceed from there to a better approximation. For x >> 1, I was thinking y^2 = 1 would be a first approximation, but again I don't know how to get any farther than that.
thanks
I'd multiply through by y', then note that you can integrate each of the three terms individually to get a 1st order diff eqn.
Maybe you probably meant (y')2, in which case try writing as y'' / ( 1 - (y')2)=2 and integrate.
No, y2 was what I meant. I forgot to mention that I had tried integrating it once as you suggested above, but I wasn't able to do the resulting integral
Is there a way to integrate that?
thanks
I'm no expert on this, but it looks like an elliptic integral to me. I don't think you can do it explicitly.
to quote http://en.wikipedia.org/wiki/Elliptic_integral"
In general, elliptic integrals cannot be expressed in terms of elementary functions. Exceptions to this general rule are when P has repeated roots, or when R(x,y) contains no odd powers of y. However, with the appropriate reduction formula, every elliptic integral can be brought into a form that involves integrals over rational functions and the three canonical forms (i.e. the elliptic integrals of the first, second and third kind).
and, c + y - y3/3 won't in general have repeated roots.
OK, that helps. Perhaps I could look up an approximation to elliptic integrals, and then invert it to get y = y(x).
gel said:
to quote wikipedia
Excellent. I'll take a look at that wikipedia article. Thank you.
Also, how do you write an inline fraction, such as 1/2, so that the 1 is on top of the 2?
can't help you with inline fractions though
Well darn. I went back and checked my derivation of the d.e. and realized I had a minus sign wrong. The correct equation is (I pretty sure this time :redface: ),
\frac{1}{2}y&#039;&#039; + 2y^{\frac{1}{2}}y&#039; + y^2 = 1
So I guess I'll get to work on this one...
Suppose a solution y(x) is invertible locally, then we can define v(y)=y&#039;(x(y)), where x(y) is the inverse of y(x). Substituting this in your d.e., you get
\frac{1}{2} v \dot{v} + 2 y^{1/2} v + y^2 = 1,
where \dot{v} denotes dv/dy. This is a first order d.e. which is easier to solve. Try substituting w=v/\sqrt{y} to get rid of the square root. If you have found the solution v(y), you can find y(x) by integrating
x-x_0 = \int_{y_0}^y \frac{dy}{v(y)}
and then solving the equation for y. Good luck!
...or use Mathematica :rolleyes:. It gives two solution: y=\tan^2 (x-x_0) and y=\coth^2(x-x_0). But you should check (and find the general solution).
That is an excellent suggestion for clearing the square root. Thank you. I had found the solution y = tanh2(x-x0) by guessing and checking. What led me to guess it was the special case of a ball falling straight down (angle the velocity makes with the vertical is zero or pi, depending on how you define it) acted on by quadratic drag. In that case the non-dimensionalized speed is u = tanh(x-x0), and y = u2 in the above d.e.
The problem is, I don't know how to find a general solution for a non-linear d.e. Is there even a method of knowing how many solutions such an equation has?
Perhaps it would be better to work directly with the d.e. for the nondimensionalized velocity, u?
u(u'' + 2uu') + (u' + u2)2 = 1
edit:
this eqn. comes from the pair of equations
u(u'' + 2uu') = sin2A
(u' + u2)2 = cos2A
where A(x) is the angle of the velocity vector with the vertical, as a function of the nondimensionalized time x.
That way the special case of (u' + u2)2 = 1, which implies u'' + 2uu' = 0, would be apparent. But I'm guessing there are more solutions than that.
I will try out your suggestion. Thanks :)
