Solving 2 vectors with cross product
5 replies · 2K views · last reply
majormaaz
Two vectors are given by A = -6 i + 5 j and B = 1 i + 4 j
Find A X B (answer only in terms of i, j, k)
Find the angle between A and B (answer is terms of degrees)
All I was told was that if I set a 3x3 matrix like this:
i j k
-6 5 0
1 4 0
then AxB is the determinant
I made the 3x3 matrix and found the determinant to be only -29 k, which I am told is correct.
I have absolutely no idea on how to approach the angle problem. If I may ask, can someone get me started in the right direction for that problem?
Look up the definition of cross product (here).
You will see that you can calculate AxB in terms of a unit vector.
i j k
-6 5 0
1 4 0
Have you had the formula ##\vec a \cdot \vec b = |\vec a||\vec b|\cos\theta##? That might come in handy.
Also:
##|\vec a \times \vec b| = |\vec a||\vec b|\sin\theta##
Why thanks, you two! I vaguely remember the dot product equation from precalculus (all those years ago), but the cross product one I've never seen. Thanks!
You're welcome. I might add that since the angle between two vectors is always between 0 and ##\pi##, the dot product may be slightly more convenient because that is the principle range of the inverse cosine.
