Solving ∂²Φ/∂s² + (1/s)∂Φ/∂s - C = 0 for radial Φ
Daniel Sellers
TL;DR
I have a fairly simple non-homogeneous second order ODE to solve but I can't seem to get started with it.
I need to solve
∂2Φ/∂s2 + (1/s)*∂Φ/ds - C = 0
Where s is a radial coordinate and C is a constant.
I know this is fairly simple but I haven't had to solve a problem like this in a long time. Can someone advise me on how to begin working towards a general solution?
Is the method of undetermined coefficients the correct approach?
Thanks very much.
Substituting ##\Psi=d\Phi/ds## turns your equation into the first order equation ##\Psi'(s)+\frac{1}{s}\Psi(s)=C##. You should be able to do this with an integrating factor.
The equation is the same as $$\frac{1}{s}\frac{\partial}{\partial s}\left(s\frac{\partial \phi}{\partial s}\right)=C$$
Is there a reason for the partial derivative symbols when there is only the single variable s?
