Solving 4 Differential Equations - Tips for Exam
  • Context: Undergrad
  • Thread starter Thread starter Bimbar
6 replies · 3K views
Bimbar
I have 4 difftiate equations now I want to solve them but i have no idea
dx/dt=ax+by
dy/dt=cy+dz
dz/dt=ez+fu
du/dt=gu+hx
Given that a,b,c,d,e,f,g,h are constants.
x,y,z,u are functions(t)
This problme will appraer in thenext exam, I am sure, my taecher emphasized it many times .
Hitn me please.
Can you solve a pair of such equations?
dx/dt=ax+by
dy/dt=cy+dz
dz/dt=ez+fu
du/dt=gu+hx
Hitn me please.
Please do not double post!
https://www.physicsforums.com/showthread.php?t=109061 in Precalculus Mathematics is enough!
But do you study this in precalculus by the way?
4 gets a bit complicated!
A way to get a handle on them is to use "operator" notation. Replace the derivative by the symbol "D" (for derivative of course!) :
Dx=ax+by
Dy=cy+dz
Dz=ez+fu
Du=gu+hx
and treat the "D" as if it were a constant (as long as you are dealing with "linear equations with constant coefficients" that works!) and solve the equations for x, y, z, u: the result will involve powers of D. Replace the D by the derivative again (i.e. Dx= dx/dt, D2x= d2/dt, etc.) and solve the resulting differential equations in a single function.
Is problem easy to you ?
IF I were given specific numbers in the four equations, yes, it would be easy for me. If I were required to write a general solution including the coefficients, a- h, it would be tedious be nothing especially difficult.
Hurkyl asked before, "Can you solve a pair of such equations?". In other words is just that there are so many equations or do you not understand the concepts involved?
You can write it in matrix form:
[tex] \left[<br /> \begin{array}{cc}<br /> \frac{dx}{dt}\\<br /> \frac{dy}{dt}\\<br /> \frac{dz}{dt}\\<br /> \frac{du}{dt}<br /> \end{array}<br /> \right]<br /> =<br /> \left[<br /> \begin{array}{cccc}<br /> a & b & 0 & 0\\<br /> 0 & c & d & 0\\<br /> 0 & 0 & e & f\\<br /> h & 0 & 0 & g<br /> \end{array}<br /> \right]<br /> \cdot<br /> \left[<br /> \begin{array}{cc}<br /> x\\<br /> y\\<br /> z\\<br /> u<br /> \end{array}<br /> \right][/tex]
or
[tex]\vec {\frac{dv}{dt}} = A\cdot\vec{v}[/tex]
The solution of the scalar equation:
[tex]\frac{dv}{dt} = av[/tex]
is
[tex]v=e^{at}\cdot v_0[/tex]
Similarly, the solution of the matrix differential equation is:
[tex]\vec{v} = e^{At}\cdot \vec{v_0}[/tex]
where
[tex]e^{At} = I + At + \frac{A^2t^2}{2!} + \frac{A^3t^3}{3!}+ ...[/tex]
