Solving a Differential Equation for Temperature Change with Initial Conditions
7 replies · 2K views · last reply
TW Cantor
dT/dt + 0.4*T - 6.4 = 0
where T is the temperature at time t
initially the temperature is 86 degrees
find the temperature at t=2.3
so i rearrange the equation to get:
dT/dt + 0.4*T = 6.4
then
integral (0.4*T) dT = integral (6.4) dt
so the general solution would be:
0.2*T^2 = 6.4*t + c
since i know that T=86 when t=0 i can work out c which i calculate to be 1479.2
so my final equation is 0.2*T^2 = 6.4*t +1479.2
but when i then put t=2.3 and solve for T my equation gives out a value of around 86.5 degrees so obviously i have gone wrong somewhere? can anyone help me out :-)
First can you tell me is this answer you want when t=2.3,T=52.460 ? :smile:
that sounds better than what I've been getting :P how did you get that?
∫(dT/dt)dt=∫(6.4-0.4T) dt
T=6.4t-0.4Tt+c
T+0.4Tt=6.4t+c
T(1+0.4t)=6.4t+c
You should have answer!
dT/dt+0.4T=6.4 => (T e^(0.4t))dT=6.4 e^(0.4t) => T e^(0.4t)=16 e^(0.4t) + C
=> T=16+Ce^(-0.4t) Substituting in T(0)=86, C=70. So, T=16+70e^(-0.4t). At t=2.3 I got 43.9
oops, (T e^(0.4t))dT should be d/dT(T e^(0.4t)) or (T e^(0.4t))'. the answer is still correct though.
I was wondering how you were going to solve a differential equation without using Calculus! (I will move this to the "Calculus and beyond" Homework section.)
Your main error was right at the beginning. You have
[tex]\frac{dT}{dt}+ 0.4T- 6.4= 0[/tex]
rewrite it as
[tex]\frac{dT}{dt}+ 0.4T= 6.4[/tex]
and then have
[tex]\int 0.4T dT= 6.4dt[/tex]
How did that sum, dT/dt+ 0.4T, suddenly become a product, 0.4T dT?
Instead, as xiaoB suggest, write it as
[tex]\frac{dT}{dt}= -0.4T+ 6.4[/tex]
and integrate
[tex]\frac{dT}{0.4T+ 6.4}= -fdt[/tex]
oh ok, i haven't done differential equations in about a year and that's just the method i thought my teacher taught me haha. thanks for setting me straight though guys :-)
