Solving A Dog's Stream Crossing Challenge
  • Thread starter Thread starter Throwback24
    Challenge Stream
A dog swimming across a stream with a speed of 2 m/s in calm water faces a current of 3 m/s. To determine the time taken to cross the 50 m wide stream, the dog will take 25 seconds, calculated using the formula time equals distance divided by speed. However, due to the current, the dog will be carried downstream while crossing, which requires calculating the downstream displacement using the time and the current's speed. The resultant velocity of the dog relative to the bank can be found using vector addition, forming a right triangle with the dog's swimming speed and the current's speed. Understanding these vector components is crucial for solving the problem accurately.
Throwback24
A dog wishes to swim across a slow-moving stream. The dog can swim at 2 m/s in calm water. The current velocity is 3 m/s. The distance directly across the stream is 50 m.
If the dog points himself directly across the stream how long will it take to get across the stream?
How far downstream will the current have carried the dog when the dog gets to the other side?
What was the dogs velocity relative to the bank from where the dog started?
With a.) I'm given how fast the dog can swim and velocity of the stream? I need to find T.
b.) I don't know what they're asking :(
c.) I don't now what they're asking :(
Can you guys please break it down for me? I think with B you multiply velocity by time.
a) Velocity = displacement/time, therefore, time = ?. To find velocity, simply add the velocity of the stream and the dog. (Note: Recall that velocity is a vector). For this part, we are interested in the component of velocity perpendicular to the bank.
b) Well, from a), you'll realize that the dog doesn't actually cross the stream perpendicular to the bank because the current pushes it downstream, but at an angle. Find its displacement in the direction parallel to the bank, which can be found using the time in part a) and the component of velocity parallel to the bank.
c) This is the velocity found in a). (Note: Remember once again, velocity is a vector. There must be 2 pieces of info provided)
Time=Displacement/Velocity?!
How do you know the dog is it an angle? I thought the dog was facing the stream
Yes, but imagine this, the dog tries to swim at a velocity (and hence a route) perpendicular to the bank, but the stream has a velocity parallel to the bank, pushing it downstream as it swims. Wouldn't it be moving at an angle?
I'm sorry if I wasn't clear earlier, for a), your equation is correct... We are concerned with the component of displacement perpendicular to the bank (i.e. the distance from bank to bank) and the component of velocity perpendicular to the bank, which is solely contributed by the dog's swimming velocity.
The component of the displacement? I'm so lost lol... can you run that by me again please?
Is it like this?
2 m/s 3 m/s
Those are the two vectors no?
A.
T=D/S
=50 m/2m/s
=25 seconds
B.
C2=A2+B2
Is that correct? It's a right angle triangle......
Up is 2 m/s and sideways is 3 m/s. The resultant would be the hypotenuse correct?
How would I go about getting C?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
