Solving a first order linear IVP
17 replies · 4K views
Logan Land
Re: Logan's question at Yahoo! Answers involving an IVP with a linear 1st order ODE
How would I solve a DE like
t(dy/dt) + 7y = t^3
dy/dt +7y/t = t^2
Then do I need to find the integrating factor?
Yes, your next step is to compute the integrating factor. Can you state what it needs to be, in integral form?
MarkFL said:
Hey no worries, I was just showing you a better way to write the integrating factor, just for clarity. :D
Note: For any additional questions, I would encourage you to begin a new topic in the Differential Equations forum. It is preferable to begin a new topic for a new question so that topics do not become potentially cluttered and hard to follow.
I am happy you have registered and are participating here! (Yes)
I'm not sure what the integrating factor is but I feel like it has to do with ln since its 7y/t
Maybe e^7ln(y/t) ? (Just guessing)Thanks
You are close, but in this case we have:
$$P(t)=\frac{7}{t}$$ and so our integrating factor is:
$$e^{7\int\frac{dt}{t}}$$
Can you evaluate this and simplify?
Would that be |t^7|
So the integrating factor is t^7?
Or did I do that completely wrong
You are absolutely correct! (Yes)
So, now your next step is to multiply the ODE by this integrating factor, and observe the left side is the product of the derivative of the integrating factor and the dependent variable $y$. Can you show this?
t^7(dy/dt) + (7y/t)t^7 = t^2 t^7
(d/dx) t^7 = t^14 ?
On the left you may simplify using $$\frac{t^7}{t}=t^6$$ and on the right, recall the rule:
$$a^b\cdot a^c=a^{b+c}$$
so that the right side becomes $$t^{2+7}=t^9$$
and so you now have:
$$t^7\frac{dy}{dt}+7t^6y=t^9$$
Now, how can we rewrite the left side?
Do we write it as a differentiation of a product like my first problem?
(d/dt) t^7y = t^9
Then integrate with respect to t?
Yes, although, if I may suggest, this notation would be preferable:
d/dt(t^7·y) = t^9.
And yes, now you want to integrate with respect to $t$:
$$\int\,d\left(t^7y \right)=\int t^9\,dt$$
d/dt(t^7·y) = t^9.
integral d(t^7·y) = integral t^9 dt
t^7·y = t^10/10
y= t^3/10 + Ct^-7
y(2)=1
When I plug in the values I get a crazy number is my y not correct?
Your general solution is correct. What value do you obtain for the parameter $C$?
t(dy/dt) + 7y = t^3
dy/dt +7y/t = t^2
Another option is to recognize that this equation is Cauchy-Euler.
I think I figured C out correctly.
y= t^3/10 - (128/5)t^-7
- - - Updated - - -
Thanks for sticking with me and helping me through to the end.
Thanks again.
I get $$C=\frac{128}{5}$$ and so the solution satisfying the IVP is:
$$y(t)=\frac{t^3}{10}+\frac{128}{5t^7}$$
Ah yes my mistake I meant + but yes I got c=128/5
That's a nice observation! Since when I was a student we were not shown this method until studying higher order equations, I will demonstrate it for the OP.
We are originally given:
$$t\frac{dy}{dt}+7y=t^3$$
If we make the substitution:
$$t=e^x$$ it then follows from the chain rule that:
$$\frac{dy}{dx}=\frac{dy}{dt}\frac{dt}{dx}=\frac{dy}{dt}e^x=t\frac{dy}{dt}$$
and our ODE becomes:
$$\frac{dy}{dx}+7y=e^{3x}$$
We find our integrating factor is $$\mu(x)=e^{7x}$$:
$$e^{7x}\frac{dy}{dx}+7e^{7x}y=e^{10x}$$
$$\frac{d}{dx}\left(e^{7x}y \right)=e^{10x}$$
$$e^{7x}y=\frac{1}{10}e^{10x}+C$$
$$y(x)=\frac{e^{3x}}{10}+\frac{C}{e^{7x}}$$
Now, back-substituting for $x$ we obtain:
$$y(t)=\frac{t^3}{10}+\frac{C}{t^7}$$
Another method is simply to assume a solution of the form $y=t^{n}$. Then plug in $\dot{y}=n t^{n-1}$, so the associated homogeneous DE becomes
$$t(n t^{n-1})+7t^{n}=0,$$
or
$$t^{n}(n+7)=0.$$
For $t\not=0$, you must have $n=-7$, and then $y_{h}=A t^{-7}$. For a particular solution, assume $y_{p}=B t^{3}$, and you'll get by plugging in that $y_{p}=t^{3}/10$, and you get the solution you got by the change of variables.
