Solving a Functional Equation - Muzialis
  • Level: Graduate
  • Thread starter Thread starter muzialis
    Functional
4 replies · 2K views
muzialis
Hi All,
I am asked to produce a function such that, literally, increasing the indipendent variable by lambda will produce an increase in the function of a*lambda.
I thought about setting up an equation as follows
y(lambda*x)=a*lambda*y(x)
In general a simple solution of the functional equation y(ax)-by(x)=0 is y = Kx^(ln(a)/ln(b)). C is arbitrary
Using this solution scheme I am unable to obtain solutions independent upon lambda.
Is the task well posed at all?
Thank you very much
Muzialis
EnumaElish,
thanks for the hint.
Your set up is coherent with my description.
However I have been imprecise, the increase is specified in the task as a multiplicative factor, so my set up is the one actually that needs solving.
I am pretty sure the task was badly posed though as I do not see how a solution could exist.
But then, that is why I posted the issue.
Thanks and all the best
Muzialis
Could it mean y((1+λ)x) = (1+aλ)y(x)?
With y(λx) = aλy(x), assume (trivially) λ = 1. Then y(x) = ay(x), which is a contradiction except for a = 1. In this formulation λ has to be > 1.
EnumaElish,
I appreciate your ad absurdum reasoning. But can you find any solution for lambda > 1?
I am sure the task was badly posed. The fact is it was proposed to me by a working partner whose maths is usually very precise, so I wanted to be extra sure I was not stating nonsense.
It has been later clarified that all it was needed was a function with a derivative of lambda, locally in a point of interest.
I am curious now tough, if the set up I originally proposed has any solution at all, although I fear not.
Thank you very much
Best Regards
Muzialis
