What is the optimal communication time for a given set of parameters?
  • Thread starter Thread starter zak100
    Base Log
The discussion centers around solving the equation for communication time, expressed as t_comm = (t_s + t_wm)log(p) + 2t_h(√p - 1). Participants clarify the calculation of log(36) in base 2, correcting the misconception that log_2(36) equals 18, which is inaccurate. They provide insights on converting logarithms between different bases and emphasize the properties of logarithms, particularly regarding the product of factors. The conversation highlights the importance of precise notation in mathematical expressions. Ultimately, the original poster indicates that the problem has been resolved.
zak100
I can't solve a log base 2 equation
##\mathbf (t_s + t_wm)log(p)+ 2t_h (\sqrt{p} - 1)##
Hi,
I am trying to solve the following equation:
##\mathbf (t_s + t_wm)log(p)+ 2t_h (\sqrt{p} - 1) ##
##\mathbf (10+0.01 * 1000) log(36) + 2 * 2(5) ##
I think log(36) would be 18. Note log is ##\mathbf log_2 ##
Somebody please guide me.
Zulfi.
zak100 said:
Hi,
Neither of these is an equation. Are you trying to simplify this expression?
No.
If it were true that ##\log_2(36) = 18##, then it would also have to be true that ##2^{18} = 36##. ##\log_2(36)## is somewhere between 5 and 6, because ##32 = 2^5 < 36 < 2^6 = 64##.
Also, there are conversion formulas for changing a log in one base to a log in a different base. Most calculators don't have buttons for ##\log_2##, but they do have them for ##\log_{10}## and ##\log_e = \ln##.
Hi,
Okay, equation is:
##t_{comm} = \mathbf (t_s + t_wm)log(p)+ 2t_h (\sqrt{p} - 1) ##
I am able to find out how to calculate ##log_2##
Zulfi.
What makes you think that the log of 36 to the base 2 is 18? It's not.
zak100 said:
Hi,
Okay, equation is:
I am able to find out how to calculate ##log_2##\
Zulfi.
Here's how to convert from one log base to another, assuming you want to write ##\log_a(x)## in some other base, b.
Let ##y = \log_a(x)##
##\Leftrightarrow a^y = x##
##\Leftrightarrow \log_b(a^y) = \log_b(x)##
##\Leftrightarrow y\log_b(a) = \log_b(x)##
##\Leftrightarrow y = \frac{\log_b(x)}{\log_b(a)}##
##\Leftrightarrow \log_a(x) = \frac{\log_b(x)}{\log_b(a)}##
In the last equation, I replaced y with ##\log_a(x)##
Hi,
I tried this :
##log_2 2^2 * 9 ##
2 goes with 2 so we are left with 2 * 9 which is 18. I did something like that in my Algorithm course.
Thanks for asking.
Zulfi.
Likes Chestermiller
The log of a product of two factors is equal to the sum of the logs if the factors.
zak100 said:
Hi,
I tried this :
##log_2 2^2 * 9 ##
Is the above ##\log_2(2^2) * 9## or is it ##\log_2(2^2 * 9)##?
Without parentheses, what you wrote is ambiguous.
Also, what you have above doesn't seem related to what you were asking about:
It seems that you are still trying to figure out how to calculate ##\log_2(36)##
Simplifying your expression above, it is ##10010\log_2(36) + 20##. I don't see what this has to do with what I quoted at the top of this post.
Thanks all of you. This problem is solved now.
Zulfi.
Okay, equation is:
  • · Replies 83 ·
21K
11K
