Solving a^n + b^n = c^n for n
  • Level: Graduate
  • Thread starter Thread starter medwatt
9 replies · 3K views · last reply
medwatt
Hello.
I have encountered an equation of the form a^n + b^n = c^n. I know this looks like Fermat's equation. How can I solve for n. It doesn't matter if n is not an integer.
Thanks
Mathematics news on Phys.org
Ok the equation I'm trying to solve is :
[itex]\left[\sqrt{2+\sqrt{3}}\right]^{n}[/itex]+ [itex]\left[\sqrt{2-\sqrt{3}}\right]^{n}[/itex] = [itex]2^{n}[/itex]
[itex]^{}[/itex]
I have arrived to this point:
[itex]\left[\sqrt{2+\sqrt{3}}\right]^{2n}[/itex] + [itex]\left[2*\sqrt{2+\sqrt{3}}]\right]^{n}[/itex] - 1 =0
I think the problem is easy but there is a point I'm missing.
I know that 2 is the answer from simple observation and with the knowledge that with Fermat's type of equations an integer solution can't be more than 2.
So you want to solve
[itex]\left[\frac{\sqrt{2+\sqrt{3}}}{2}\right]^{n}+ \left[\frac{\sqrt{2-\sqrt{3}}}{2}\right]^{n}= 1[/itex]
and you know that n=2 is a solution, and I assume you know that an is decreasing for 0<a<1, so that there can't be more solutions.
okay id try n=0, then n=1 then n=2... and see which ones or one are true. basically you're trying to find n.
also i think you are on the right track using fermat's last theorem (proved by Andrew Wiles in 1995) as an upper bound for n
I need to show that n=2. The answer 2 in this problem was obvious. What would be the general solution to such equations if n is not an integer (i.2 we cannot guess it by simple observation).
[itex]^{}[/itex]
Do you need an exact analytic answer or will a numerical approximation suffice?
It doesn't matter if n is an integer or not. I just want a way to solve the equation because suppose guess the answer was not so easy, how can one solve it without of course a computer.
Yes I think it looks like Binet's formula for Fibonacci sequence.
