Solving a Quadratic Equation with Two Variables
6 replies · 2K views
Ashley1nOnly
X^2-yx+y^2-7=0
-b +- sqrt(b^2-4ac)/2a
Trying to complete the square with two variables
(x^2-yx)+(y^2)=7
(X^2-yx+y/2)+y^2=7
Where else from here. I'm just having problems because of the y variable
Ashley1nOnly said:
X^2-yx+y^2-7=0
What's the complete problem statement? IOW, what are you supposed to do here?
(x^2-yx)+(y^2)=7
(X^2-yx+y/2)+y^2=7
The original equation was a differential equation
(2x-y)dx+(2y-X)dy= 0
Which I solved and got
X^2-yx+y^2=7
It took the form of
M(X,y)dx+N(X,y)=0
M(partial y)= N(partial X)
So it had an exact solution
I then continued the rest of the steps and got my final answer but it needs to be in terms of y.
The final answer is
Y=[x+sqrt(28-3x^2)]/2, |x|<sqrt(28/3)
I'm trying to transform my answer into their final answer.
I need help completing the squares so that I can use the quadratic equation to solve for y.
You need y as function of x. So write y2-yx+x2-7 in form (y-x/2)2+f(x)
@Ashley1nOnly, your first post should have started like this:
Solve for y in the equation X^2-yx+y^2-7=0
One other thing -- what you wrote above would be interpreted by most as
$$-b \pm \frac{\sqrt{b^2 - 4ac}}{2} a$$
Ashley1nOnly said:
X^2-yx+y^2-7=0
(x^2-yx)+(y^2)=7
(X^2-yx+y/2)+y^2=7
You have an equation of the form ##y^2 + b y + c = 0##, with appropriate ##b## and ##c##. The solution forms
$$y_1 = \frac{-b + \sqrt{b^2 - 4 c}}{2} , \; y_2 = \frac{-b - \sqrt{b^2 - 4 c}}{2} $$
will give you the answer. It does not matter if ##b,c## are numerical constants, or if they are 1000-page formulas containing 500 other variables; as long as they do not contain ##y##, the quadratic solution formula holds and you are good to go.
