Solving a Re-arranging Problem: Making r the Subject
  • Context: Graduate
  • Thread starter Thread starter lostidentity
3 replies · 2K views
lostidentity
I'm trying integrate the following equation and make r the subject
[tex]\frac{dr}{dt} = \Phi - \Psi \frac{2}{r}\frac{dr}{dt}[/tex]
I first collect the derivative terms together and integrate the equation with respect to r and t to obtain
[tex]r + 2\Psi\ln{r} = \Phi{t} + r_0[/tex]
where r0 is the constant of integration. My question is how would I make r the subject of the above equation?
Many thanks.
hi lostidentity! :smile:
not possible!
(unless you define the LHS to be f(r), in which case it's r = f-1(RHS) :wink:)
I'm wondering if there is another way to solve the ODE I gave in the previous post, i.e.
[tex]\left(1+2\frac{\Psi}{r}\right)\frac{dr}{dt} = \Phi[/tex]
Check this very very carefully
[tex]r = 2 \Psi lambert\left(\frac{e^{\frac{t\Phi+c}{2 \Psi}}}{2 \Psi}\right)[/tex]
where c is some constant and where lambert gives the principle solution for w in z=w e^w.
When I substitute this back into the original ODE it seems to check, but do not trust this until you have triple checked it.
