How to solve a recursion relation with a constant using hints?
  • Thread starter Thread starter spaghetti3451
    Recursion Relation
The discussion focuses on solving the recursion relation y_k = k(2j-k+1)y_{k-1} to derive the expression y_k = (k!(2j)!)/(2j-k)!. The user seeks hints for the solution, noting that y_0 = 1. The solution involves expressing y_k in terms of products, leading to the formulation y_k = (k!) * (product of (2j-i+1) for i from 1 to k). Ultimately, the final result confirms the desired expression for y_k. The thread concludes with a successful derivation of the recursion relation.
spaghetti3451
I have the recursion relation ##y_{k}=k(2j-k+1)y_{k-1}##
and I would like to solve it to obtain ##y_{k}=\frac{k!(2j)!}{(2j-k)!}##.
Can you provide some hints on how I might proceed?
P.S.: ##j## is a constant.
Mathematics news on Phys.org
## \frac{y_k}{y_1} = \prod_{i = 2}^k \frac{y_i}{y_{i-1}} ##
I forgot to mention that ##y_{0}=1##.
All right, then, we have
##\frac{y_k}{y_0} = \prod_{i = 1}^k \frac{y_i}{y_{i-1}}##
##y_k = \prod_{i=1}^{k} i(2j-i+1)##
##y_k = \bigg(\prod_{i=1}^{k} i\bigg) \bigg(\prod_{i=1}^{k} (2j-i+1)\bigg)##
##y_k = (k!) \bigg(\prod_{i=1}^{k} (2j-(i-1))\bigg)##
##y_k = (k!) \frac{(2j)!}{(2j-k)!}##
Thanks!
You're welcome
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
