Solving a Skateboarder's Projectile Motion Problem
The problem involves a skateboarder launching off a ramp inclined at 30 degrees with an initial velocity of 7 m/s. The goal is to determine how far the skateboarder will land from the end of the ramp, considering aspects of projectile motion.
  • Participants discuss the need to consider air resistance and gravity's effect on the skateboarder's motion. There are inquiries about how to calculate the horizontal and vertical components of velocity at the end of the ramp, as well as the use of kinematic equations.
Some participants have provided guidance on separating the motion into horizontal and vertical components and suggested creating a vector diagram to aid in understanding the problem. There is an ongoing exploration of how to find the vertical velocity, but no consensus has been reached on the specific steps to take.
Participants are working under the assumption that air resistance is negligible, which may simplify the calculations. There is also a focus on understanding the implications of gravity on the skateboarder's trajectory.
Black-Enigma
1. A skateboarder starts at the bottom of a 1 metre ramp, with an incline of 30 degrees. The skateboarders initial velocity is 7m/s. How far will the skateboarder land from the end of the ramp?
I firstly worked out the hypotenuse and adjacent lengths of the ramp. I then worked out the velocity of the skateboarder at the end of the ramp. I am having trouble with piecing together the projectile motion. Could somebody help me through this problem. I am not looking for an answer, just help.
Thanks
First thing is, is there any air resistance? Two other questions that will effect your answer, do you the force of gravity?
If there is not, finding the displacement will be easier for you. The first thing is, you will need to know is the horizontal and vertical velocities.
Do you also know what equations you will need?
P.S. If there is no air resistance, remember that the vertical and horizontal velocities are separate from each other.
Thanks for your response.If air resistance is not considered, how do I find out the vertical and horizontal velocities at the end of the ramp? For the equations, I would think just the usual kinematic equations, separated into horizontal and vertical components.
separating into horizontal and vertical components would be a good idea.
If you consider just the vertical part of the problem, the period of the jump is going to just be how long it takes gravity to overcome the skater's upward velocity.
it would be a very good idea to find out the vertical velocity, then with that, a lot of doors open up that leads to your answer.
Im having trouble finding the y velocity. I am not sure where to start.
Okay, Make a vector diagram of the ramp, the initial velocity at 30 degrees and you can then find the vertical velocity.
Remember this: when trying to work out a problem that at first does not make sense, draw a vector diagram (if applicable), it is remarkable how useful they really are.
  • · Replies 18 ·
