Solving a trigonometric equation
The forum discussion focuses on solving the trigonometric equation 10sin²x + 10sin x cos x - cos²x = 2 for x in the range of 0 to 360 degrees. Participants suggest using the double angle identities, specifically sin 2x = 2sin x cos x and cos 2x = 1 - 2sin²x, to transform the equation into a more manageable form. The equation can be rewritten as 11sin²x + 5sin 2x - 3 = 0, leading to a standard form A sin y + B cos y = C. This approach allows for the application of trigonometric identities to find the solution.
  • Understanding of trigonometric identities, including double angle formulas.
  • Familiarity with solving quadratic equations in trigonometric form.
  • Knowledge of the unit circle and angle measures in degrees.
  • Basic algebraic manipulation skills for transforming equations.
  • Study the derivation and application of double angle formulas in trigonometry.
  • Learn how to convert trigonometric equations into standard forms for easier solving.
  • Explore the use of Wolfram Alpha for solving complex trigonometric equations.
  • Practice solving equations of the form A cos t + B sin t = C using trigonometric identities.
Students, educators, and anyone interested in mastering trigonometric equations, particularly those preparing for exams or engaging in advanced mathematics discussions.
chwala
Find the value of x between 0 degrees and 360 degree satisfying the equation
10sin^2x+ 10sin x cos x - cos^2x = 2 this is how i have attempted.....
10 sin^x+ 10sin2x/2 - cos^x = 2
I used the property sin 2x = 2 sin x cos x and substituted sin x cos x with sin 2x/2 giving me....
11sin^2x + 5sin 2x -3 =0 on reaching here i got stuck...kindly advise
Mathematics news on Phys.org
Use the identity \sin^2 x = \frac12(1 - \cos 2x).
is this the way to go bro...
11(0.5(1-cos 2x)+5 sin 2x - 3 =0
Honestly, this doesn't look easy in any way, if I'm completely honest. I did some checking on Wolfram-Alpha to see what needs to be done, and it looks like it needs to be somehow written in terms of the tangent function... which I suppose you could do by dividing the whole thing by cos(2x) and then rewriting the sec(2x) that comes up in terms of the tangent function.
Not that that's going to be easy, but it definitely looks like the way to go.
i need more insight on this any help or clue, Char.Limit i still don't understand.....
Have you not had to solve problems of the form <br /> A \cos t + B \sin t = C before? This is basic trig: one uses the identity <br /> R\cos(t - \alpha) = R\cos\alpha \cos t + R\sin \alpha \sin t. Setting this equal to A \cos t + B \sin t
yields R \cos \alpha = A \\ R \sin \alpha = B which are easily solved for R and \tan \alpha, and then R \cos(t - \alpha) = C is easily solved for t.
Huh. That's actually not any trig I ever learned... very good to know, though. My bad, pas, that's definitely the way to go.
Express everything in terms of trig ratios of twice the angle using the double angle formulae:
\sin 2x = 2\sin x \cos x
and
\cos 2x = 2\cos^2 x - 1 = 1 - 2\sin^2 x
(you'll need both forms of the latter identity).
Then, letting y = 2x (just for clarity), you can transform the equation into the form
A \sin y + B \cos y = C
after which you can proceed as pasmith advised.
thanks i attempted this as follows
-11/2 cos 2x + 5 sin 2x = -5/2
-11 cos 2x + 10sin 2x=-5 and letting y=2x
-11 cos y+10sin y= -5
now this is in the form Acos t + Bsin t = c...from here and using the identity given by pasmith
Rcos α= -11 am i on the correct path thanks again curious3141,char.limit and pasmith.
i also need advise on how i can post using mathematical language/symbols like the ones used by pasmith....
  • · Replies 28 ·
