Solving an ODE with the Laplace transform
8 replies · 3K views
PainterGuy
Moved from a technical forum, so homework template missing
Hi again,
The previous problem was done using y′′(t)+2y′(t)+10y(t)=10 with with intial condition y(0⁻)=0.
In the following case, I'm using an initial condition and setting the right hand side equal to zero.
Find y(t) for the following differential equation with intial condition y(0⁻)=4.
y′′(t)+2y′(t)+10y(t)=0
Using the following formulas.
ℒy(t)=Y(s)
ℒ{y′(t)}=sY(s)-f(0⁻)=sY(s)-4
ℒ{y′′(t)}=ℒ{(sY(s)-4)′}=ℒ{(sY(s)′-4′)}=ℒ{(sY(s)′)}=s²Y(s)-4s
⇒{s²Y(s)-4s}+2{sY(s)-4}+10Y(s)=0
⇒s²Y(s)-4s+2sY(s)-8+10Y(s)=0
⇒s²Y(s)+2sY(s)+10Y(s)-4s-8=0
⇒s²Y(s)+2sY(s)+10Y(s)=4s+8
⇒Y(s){s²+2s+10}=4s+8
⇒Y(s) = (4s+8) / (s²+2s+10)
Now finding the inverse Laplace transform.
Method 1:
https://www.physicsforums.com/attac...261154/?hash=ab39a4f0474f3384a6a5c37cdc441e05
Method 2:
This method I found from this video.
Question:
You can see that I'm getting different functions, f(t), for the mentioned methods. Where am I going wrong? Which f(t) is correct? Thank you for the help.
In your first attempt, you complete the square incorrectly: ##s^2+2s+10 = (s+1)^2+9##.
Mark44 said:
For a 2nd-order DE, you need two initial conditions, typically f(0) and f'(0).
This formula from above isn't correct:
Thank you. Yes, sorry, I didn't realize it at that time.
The previous problem was done using y′′(t)+2y′(t)+10y(t)=10 with with intial condition y(0⁻)=0. If y(t) represents displacement then its first derivative would be velocity function, v(t). As an initial condition it is assumed that y'(0⁻)=v(0⁻)=0. Now we have two initial conditions, i.e. two pieces of information about the system just a moment before it's analytically observed.
I have corrected Method 1 below. Now the results from both Methods agree. But I have a related question which is below the plot.
Question:
Apparently I completed the square wrongly but overall my completed square agrees with the original expression s²+2s+10. So, does completing a square method require that no fractions or decimals should be used, or what else is wrong with my method? Please guide me.
s²+2αs+α²+β²=s²+2s+10=s²+2(1/2)s+(1/2)²+(3.1225)²={s+(1/2)}²+3.1225²=(s+α)²+β²
Without assuming what the answer is, try simplifying that expression. I guarantee you do not get what you started with.
Let's try it: s²+2(1/2)s+(1/2)²+(3.1225)² =s²+(2/2)s+(1/4)+9.750=s²+s+0.25+9.750=s²+s+10
original expression: s²+2s+10
s²+2s+10 ≠ s²+s+10
Sorry! :sorry:
Hi,
I read somewhere that for a transfer function, the number of poles (roots of denominator) and zeros (roots of numerator) is equal. The transfer function from post #1, Y(s)=(4s+8) / (s²+2s+10), has poles at -1±3i and a zero at -2. Where is the second zero located? Thank you for the help!
Could someone please comment on my previous post?
Original expression: Y(s)=(4s+8) / (s²+2s+10)
I think we could divide both numerator and denominator by "s²".
(1/s²)(4s+8) / (1/s²)(s²+2s+10) = (4/s+8/s²) / (1+2/s+10/s²)
As s→∞ (4/s+8/s²) / (1+2/s+10/s²) = 0/1 = 0
I think it gives us a zero at infinity.
