Solving Brightness Equation with Procyon: 7L☉ and 11.41 light years
  • Thread starter Thread starter vbillej
    Luminosity Solar
The discussion revolves around calculating the brightness of the star Procyon using the formula Brightness = Luminosity/4πr². Procyon has a luminosity of 7L☉ and is located 11.41 light years away. The correct calculation yields a brightness of approximately 0.004 L☉ watts per square light year. Participants clarify that L☉ represents a unit of solar luminosity, and the numerical value should not be directly input into a calculator as a single entity. The confusion stemmed from misplacing the values in the equation, which was resolved with proper guidance.
vbillej
In a question is says that Brightness = Luminosity/4πr₂ (for a star).
Procyon = 7L☉ and 11.41 light years as distance.
the equation in B= 7L☉/ 4π(11.41)₂
the answer turned out to be 0.004 L☉ watts per square light year (its a textbook question). What i don't understand is what is 7L☉, what's its value. I read that L☉ is approx the suns luminosity so i did 7(3.839 × 10^26). but still getting the wrong answer.
Thanks
vbillej
Astronomy news on Phys.org
Thanks
vbillej
I don't exactly understand what the problem is.
I just don't get what 7L☉ is, i looked up L☉ but i still don't really understand how the answer was 0.004 L☉.
Like how would i put 7L☉ into a calculator.
L☉ is just a unit, specifically, the unit solar luminosity. Its value is defined to be the luminosity of the sun. You don't put 7L☉ into a calculator any more than you put 7 meters or 7 seconds into a calculator, you only calculate the numbers, the units are your responsibility.
The equation you mentioned has units of L☉/ly^2, which is exactly what you wanted, is it not?
Read the answer carefully.
7 is the AMOUNT L is the UNITS. This means how luminous the object is compared to the currently accepted luminosity of our Sun. You are correct in your conversion from solar luminosity to just get the luminosity for the star but you don't need to do that.
The stars brightness or its flux is given by the equation:
f=\frac{L}{4\pi d^2}
So you are given the stars luminosity and its distance plug that into the equation and you get appox. 0.00428092 (using google to calculate). Your units would be L Watts per squared light year... which is what is in the back of the textbook.
and I've noticed that while I was fixing some problems with my latexing Nabeshin had already answered you :P
Thanks guys, i found out that i put 7L☉/ 4π(11.41)₂ as a fraction in the calculator... -_- haha
thank your very much for your help
vbillej
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
