How do you solve cos(α+θ)=0 for different values of α?
  • Thread starter Thread starter PainterGuy
PainterGuy
How do I solve cos(a+θ)=0?
Please check the posting.
Hi,
I was trying to solve y=cos(α+θ) where α is a constant and θ has range [0,2π).
If α=3 is assumed, the solution is as shown below and it makes sense
\theta_{1}=\frac{3}{2}(\pi-2)
\theta_{2}=\frac{1}{2}(5 \pi-6)
But if I don't use any specific value for α, the solution doesn't make sense to me.
\pi n-\frac{5 \pi}{2} \leq \alpha \leq \pi n-\frac{\pi}{2} and \theta=\pi\left(n-\frac{1}{2}\right)-\alpha and n \in \mathbb{Z}
Source: https://www.wolframalpha.com/input/?i=solve+cos(α+θ)=0+for+θ+from+0+to+2pi
Somewhere I found the solution to be as shown below but don't understand why \cos ^{-1} y is used, and please note that α is not given any specific value:
\theta_{1}=\left(\cos ^{-1} \mathrm{y}\right)-\alpha
\theta_{2}=2 \pi-\left(\cos ^{-1} \mathrm{y}\right)-\alpha
Could you please help me? It's not homework but I still thought I better post it here nonetheless.
\alpha+\theta=\pi(n+\frac{1}{2})
\theta=\pi(n+\frac{1}{2})-\alpha
integer n should be chosen properly so that
0 < \theta < 2\pi
You may make use of floor function to show solutions explicitly.
Likes PainterGuy
What happens if you add ##\alpha## to those solutions for ##\theta##?
Do you know how the function ##\cos^{-1}## is defined?
Likes PainterGuy
Yes, I'd say I know how arccosine is defined. Cosine of an angle, cos(angle), gives you the ratio of base/hypotenuse and arccosine of the ratio, arccosine(base/hypotenuse), gives the corresponding angle.
At an elementary level, the cosine is defined in terms of a right-angled triangle, but a question like this demands a more general definition.
More generally, ##\cos \theta## it is the x-coordinate on the unit circle corresponding to an angle ##\theta## as measured anti-clockwise from the positive x-axis.
You've missed the key point that the cosine is not a one-to-one function. E.g. ##\cos \theta = \cos (-\theta)##. It is not necessarily the case, therefore, that ##\cos^{-1}(cos \theta) = \theta##
This means you need a slightly more sophisticated definition of the inverse cosine. I'll let you look that up.
Likes PainterGuy
Thank you for pointing this out.
On a unit circle the cosine is the length of the adjacent side (which is the x-coordinate) divided by the length of the hypotenuse (which is 1). So, as you said, the cosine is just the x-coordinate.
The domain of the inverse cosine function is [−1,1] and the range is [0,π]. That means a positive value will yield a 1st quadrant angle and a negative value will yield a 2nd quadrant angle.Helpful links:
https://www.mathwords.com/c/cosine_inverse.htm
/watch?v=ZEAgtXTIxk0 (add youtube.com in front)
/watch?v=xEGZsWgCn-Q
https://www.khanacademy.org/math/al...0c9fb89:unit-circle/a/trig-unit-circle-review
0 < \theta < 2\pi
Thanks!
But it also involves α in addition to n; two variables.
Also, I don't see how the floor function could be used here.
Okay. So for every point ##y## in ##[-1,1]## there are two values of ##\theta## for which ##\cos \theta = y##.
Can you see the relationship between the two values of ##y##?
Likes PainterGuy
I think both values of y should be equal.
Say
\frac{1}{4}-\frac{\alpha}{2\pi}=123456.789
\frac{3}{4}-\frac{\alpha}{2\pi}=123457.289
You will be able to reduce them to 0.789, 0.289 using floor function.
Likes PainterGuy
They are not. The graph of ##\cos \theta## is symmetric about ##\theta = \pi##. For every value of ##y## there are two values of ##\theta## for which ##\cos \theta = y##: one in the interval ##[0, \pi]## and one in the interval ##[\pi, 2\pi]##. The only exception is ##y = -1##, for which there is only ##\theta = \pi##.
This symmetry may be expressed in two ways (these are common trig identities):$$\cos (\pi - \theta) = \cos (\pi + \theta)$$ or $$\cos \theta = \cos(2\pi - \theta)$$You should convince yourself of these by looking at the graph of ##\cos \theta## on the interval ##[0, 2\pi]##.
Likes PainterGuy
Whoah, this seems to have gone WAY off track. Assuming this is the question:
Then you are going about this completely the wrong way.
Here is the first step along the right way: for what values of ## x ## is ## \cos x = 0 ## true?
Likes SammyS
If you read the OP that ##0## should be a general ##y##. Given the solution, I assume the first line is a typo.
Likes pbuk
That is also a possibility, but it doesn't fit with this part of the OP which is clearly referring to ## \cos (\alpha + \theta) = 0 ##.
Likes PeroK
@PainterGuy please clarify whether you are only looking at the special case where ##y = 0##. That said, this is as good an opportunity as any to understand the inverse cosine function generally!
Likes SammyS
Yes, I was trying to find the roots of y=cos(α+θ) which would require y=0. α is a constant and I'd assume that it's not zero.
Okay, so we have an answer in post #2. Without knowing a range for ##\alpha## it looks a bit messy to try to keep ##\theta## in a certain range. Is that what you want to do?
Likes PainterGuy
Why are you writing this in such a complicated way? You don't need to introduce ## y ##, you are simply trying to find values of ## \theta ## that satisfy ## cos (\alpha + \theta) = 0 ##.
The first step to answer that question is answering:
Likes PainterGuy
Note that to get the answer from Wolfram Alpha you simply need to enter "solve cos(\alpha + \theta) = 0 for \theta", but in order to use a tool like Wolfram Alpha you need to have some understanding of the basics.
Yes, I was trying to keep the theta in the given range without knowing the range for alpha.
cos(x)=0 for x=pi/2 and x=3pi/2 if x is restricted to 0 to 2pi.
Right, let's just look at the first solution, ## x = \dfrac \pi 2 ##.
Look back at the original problem ## \cos(\alpha + \theta) = 0 ##. What I have done is made a substitution ## x = \alpha + \theta ##. Using substitutions is an important tool in solving mathematical problems; choosing the right substitution makes the problem easier to solve. We can now write an equation with the substitution I made on the LHS and the solution you found for x on the RHS:
$$ \alpha + \theta = \dfrac \pi 2 $$
and we can simplify this to
$$ \theta = \dfrac \pi 2 - \alpha $$
Note that this will only give ## 0 \le \theta \lt 2 \pi ## for certain values of ## \alpha ## (what are these?)
You can do something similar with your other solution for ## x ##, and again look at how this works for different values of ## \alpha ##.
  • · Replies 17 ·
