Solving driven differential equations
The discussion revolves around a damped differential equation modeling a car's suspension system, specifically the equation z'' + 2z' + z = f(t), where z represents vertical displacement. The function f(t) is defined based on the car's interaction with "catseyes" on the road, which impart unit impulses to the system at regular intervals. Participants are tasked with solving for z(t) given initial conditions and exploring the effects of various parameters such as the number of catseyes (K), distance between them (d), and the car's speed (v).
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to express f(t) in terms of Heaviside step functions and consider using Laplace transforms to solve the ordinary differential equation (ODE). There are inquiries about the Laplace transform of delta functions and how to handle summations in the context of the transform.
Some participants have made initial attempts to apply Laplace transforms, while others seek clarification on specific steps in the process. There is an ongoing exploration of how to incorporate the summation of impulses into the solution. Guidance has been provided regarding the linearity of the Laplace transform and its inverse, but no consensus has been reached on the final form of the solution.
Participants are working under the constraints of the problem statement, which includes specific initial conditions and parameters that affect the behavior of the system. There is a focus on understanding the implications of different values for K, d, and v without resolving the overall solution.
danj303
The suspension system of a car is designed so that it is a damped system described by
where z is the vertical displacement of the car from its rest position. The car is driven over a (smooth!) road which has "catseye" embedded in the road surface every d metres. Assume that each time the car passes over a catseye, the suspension system receives a unit impulse. Thus, if the car is driven with velocity v m/s over K + 1 catseyes then
f(t) = (see attachment)
(a) Find z(t) when z(0) = z'(0) = 0.
(b) Plot the solutions for K = 10 and K = 50 with v = 10 What is the eff ect of a larger K? Fix K = 50. Let v = 10 and plot the solutions for d = 5 and d = 10 on the same axes. What is the e ffect of the distance between the cateyes? Let d = 10 and plot the solutions for v = 10 and v = 20. What is the e ffect of speed?
on attachment
on attachment
What have you tried?
Ive got no idea where to start. Thats the problem. I would assume f(t) needs to be expressed in terms of heaviside step functions and then the differential equation solved but I am not sure.
Have you learned the method of using Laplace transforms to solve ODEs? If so, try that...
Ok that's all well and good but can you explain a little bit further. We have covered laplace transforms but only recently and I am trying to work thorugh some problems to understand how it works. Thanks
The first step is always to take rthe Laplace transform of both sides of the ODE...what do you get when you do that?
The left side is easy if you set it to equal zero. The laplace transform is
s^2*Y(s) + 2s*Y(s) + Y(s) = 0
but I am not sure about the right hand side with the sum from 0 to K of the dirac delta function.
Do you know how to take the Laplace transform of a single delta function? If so, just use the fact that the Laplace transform is linear:
[tex]\mathcal{L}\left[g_1(t)+g_2(t)\right]=\mathcal{L}\left[g_1(t)\right]+\mathcal{L}\left[g_2(t)\right][/tex]
Im not sure about that part. Can you elaborate.
You're not sure how to take the LT odf a delta function? Or you aren't sure how to add a bunch together?
Im not sure how to take the laplace transform of δ(t-kd/v)
It's probably in your textbook, so you might try opening that up and reading part of it :wink:...or, you can use the definition of Laplace transform and the definition of delta function and calculate it directly...
Alright after some time I get the laplace transform of the Right hand side as e-(kd/v*s)
and then sloving the entire equation for Y(s) I get
Y(s) = e-(kd/v*s)/s2+2s+1
But does this take into account the sumation and then how do I take the inverse laplace transform to solve the DE
No, it doesn't take into account the summation. The Laplace transform of the righthand side is
[tex]L[f(t)] = L\left[\sum_{k=0}^K \delta(t-kd/v)\right] = \sum_{k=0}^K L[\delta(t-kd/v)][/tex]
where the last step uses the linearity of the Laplace transform. What you calculated is the inside of the last summation.
The exponential factor merely indicates a delay. To find the inverse Laplace transform, you temporarily neglect it, find the inverse transform of the rest, and then time-shift the answer. For example, suppose X(s)=e2s/(s+1). To find x(t), you first find the inverse Laplace transform of 1/(s+1), which is e-t. Now you time-shift the answer by 2, so x(t)=e-(t-2)u(t-2).
I find
z(t) = t e-(t-kd/v) Heaviside(t-kd/v)
The only thing I am not sure about is fitting the summation back in. How do I do this??
danj303 said:
I find
Close, but shouldn't your [itex]t[/itex] out front really be [itex]\left(t-\frac{kd}{v}\right)[/itex]?
Not only is the Laplace transform linear, so is its inverse. That means if [tex]Z(s)=\sum_{k=0}^K g_k(s)[/itex] , then <br /> <br /> [tex]z(t)=\mathcal{L}^{-1}\left[\sum_{k=0}^K g_k(s)\right]=\sum_{k=0}^K \mathcal{L}^{-1}\left[g_k(s)\right][/tex][/tex]
