Solving E&M Homework Problem: Find Force on 3rd Charge
The discussion focuses on solving a physics problem involving three charged particles and calculating the forces acting on the third charge. The key points include the application of Coulomb's Law to determine the x and y components of the forces exerted by the first two charges on the third charge. The user initially struggles with calculating the total force and its direction, receiving guidance on using trigonometric functions appropriately. After some corrections, the user successfully calculates the x-component but remains confused about the y-component and the total force's angle. The conversation emphasizes the importance of understanding trigonometric relationships in solving such physics problems effectively.
badirishluck
A particle of charge 5.03 nC is placed at the origin of an
xy-coordinate system
A second particle of charge -2.00 nC is placed on the positive x-axis at x = 4.04 cm.
A third particle, of charge 6.01 nC is now placed at the point x = 4.04 cm, y = 3.00 cm.
Find the x-component of the total force exerted on the third charge by the other two.
Find the y-component of the total force exerted on the third charge by the other two.
Find the magnitude of the total force acting on the third charge.
Find the direction of the total force acting on the third charge in radians.
Coulomb's Law = k(q1q2)/r^2
The answers I got were
Fx = 6.38*10^-5
Fy = -3.49*10^-5
Ft =
Direction was .944 radians
all of which were wrong. I don't know how to calculate the Ftotal, or what I did wrong.
Just giving the numerical answers doesn't help to tell what you did wrong, now does it? Can you give a detailed working of finding Fx? That's the easy one, since the -2nC charge doesn't affect Fx.
Your equation is correct. For the x-component, only the first particle will influence the motion of the third particle along the x-axis; the second particle has the same x-coordinate, and therefore, will only change the motion of the the third particle along the y-axis. To accomplish this, find the force of the first particle on the third particle in terms of magnitude and angle, then use trigonometry to compute the x-component motion. Use a diagram to illustrate this force vector and its components. For the remaining parts, add the remaining force vector to your diagram and use more trigonometry.
This is what i did to find Fx:
To find r between Particle 1 (5.03*10^-9) and Particle 3 (6.01*10^-9)
Sqrt[(3*10^-2)^2 + (4.04*10^-2)^2] = 5.032*10^-2
To find the F13:
(9*10^9)*(6.01*10^-9)*[(5.03*10^-9)/((5.0321*10^-2)^2)
= (5.409*10^1)*(1.9864*10^-6)
=1.07*10^-4
Fx:
Tan(a) = 4.04/3 = 53.40
(1.07*10^-4)*cos53.40 = 6.38*10^-5
This is the first problem. Tan(a) = opposite/adjacent = 3/4.04. I recommend that you learn your trigonometric identities as soon as possible as they are fundamental to solving many problems.
Oh boy. How silly of me. I was able to get the Fx component this way. Thank you so much!
However, I am still confused on how to find the Fy and the Ftotal.
Using the same procedure, I got
6.38*10^-5 for Fy(13) and -7.2*10^-5 for Fy(23)
To get the Fytotal
6.38*10^-5 - 7.2*10^-5 = -8.2*10^-6.
The answer was wrong. What do I need to do instead and how do I find the magnitude of the total force?
Thank you so much!
Since you know the angle and magnitude of the force vector of particle 1 on particle 3, you can determine the x-component (which you have recently done) and also the y-component of this force. What does the force vector of particle 2 on particle 3 look like? What is its direction and magnitude? We discussed particle 2 previously. Now, just add the vector components together.
I was able to find the Fy and Ftotal components. How do I find the angle of the total force in radians.
I tried:
Fy/Fx = (-5.7*10^-5)/(8.61*10^-5) = .662
Cos.662 = .789 radians
Sin.662 = .614 radians
Tan.662 = .779 radians
All of these were wrong. What should I try now?
You might try understanding what you are doing instead of using random trig functions. Fy/Ft is the sine of the angle. Use an inverse trig function to get the angle. And don't just try all of them. Pick the right one.
