Solving 3((e^x)-1)-xe^x=0 Equation
  • Thread starter Thread starter hamamo
The equation 3((e^x)-1)-xe^x=0 cannot be solved algebraically, but solutions can be approximated graphically or using the Lambert W function. The discussion highlights that x=0 is one known solution, while another approximate solution is around x=2.82. The equation is related to Black's law and Wien's displacement law, aiming to calculate Wien's constant at the maximum wavelength of black body radiation. A method using Newton-Raphson for calculating the Lambert W function is suggested, providing a fast-converging iterative approach. Overall, the conversation focuses on finding numerical solutions and utilizing specific mathematical functions for complex equations.
hamamo
hi there;
please can anyone help me solving this
3((e^x)-1)-xe^x=0
sorry i couldn't use more elegant form to write the equation
i use some software and they help
but i can't do it in hand
hamamo said:
hi there;
3((e^x)-1)-xe^x=0
3(e^{x}-1)-xe^{x}=0 I do not believe you can solve this one algebraically, one can only approximate the solution to these kind of equations.
i think a graphical method is usefull...
ciao
thanx for the reply up there
but i search more and i found this kind of equation can be solved using
Lambart w-function
or omega function, the problem i couldn't have more information about this function else some expansion series and i can't even write a code to solve or to find a value in lambart function
any more help will be useful
thanx
can you help me using the latex
By inspection we can see x=0 is a solution. Do you have any reasoning to believe there are other solutions?
Edit = maybe I was to hasty - there seems that there is at least one more solution.
If you click on the formula, you will see the code in a new window.
tanx for the reply
the 0 solution i know about it
and there is another solution if you graph the equation you can find it approximately
its about 2.something
by the way
this equation is a result for the Blanck's low and Wien's displacement low
i want to calculate the Wien's constant at the maximum wave length of black body radiation
so
i differentiate Blanck's low and solve the equation for which x have a maximum value
and the result is something like this equation
which now i need to solve for x to find max and min value
Lambart w-function
thanx
Hello Hamamo, if you want some code to calculate the Lambert W function, you might consider using the definition of it and the method of Newton-Raphson. The definition as you might know is:
X=Ye^Y \qquad \rightarrow \qquad Y=W(X)
Thus if you define a function f as:
f=Ye^Y-X
You can use the method of Newton Raphson to be for calculating this function:
Y_{n+1}=Y_n-\frac{Y_ne^{Y_n}-X}{e^{Y_n}(Y_n+1)}
Or:
Y_{n+1}=\frac{e^{Y_n}Y_n^2+X}{e^{Y_n}(Y_n+1)}
Take 0 as start value and use this iterative scheme to calculate the solution as the resulting value of the Lambert W function. It converges extremely fast. 5 iterations for the value of the function you are looking to solve.
best regards, Coomast
[Edit] The results of the iteration if you use it on your function:
step n Yn Yn+1
1 0 -0.149361
2 -0.149361 -0.177647
3 -0.177647 -0.178560
4 -0.178560 -0.178561
5 -0.178561 -0.178561
Which is x-3, thus x=2.821439 is the one you need
thanx coomast
you r helpfull that's what i need
thanx again
