Solving Equations of Complex Numbers
ENGR_student
Show that (1+i) is a root of the equation z4=-4 and find the other roots in the form a+bi where (a) and (b) are real.
Using De Moivre's Theorem
zn=[rn,nθ]
Modulus(absolute value of z) = 4
Argument = ?
r4=4 → r = (4)^(1/5)
argument(z) = ∏/4 (not sure if that was right...)
Let:
[r4],5θ] = [4,2n∏ + ∏/4]
and then solve for the solutions for (n=-1,-2,1,2...im assuming to make it symmetrical)
zn=[rn,nθ]
Argument = ?
Let:
No.
Where is 1+i in the complex plane? You can draw it, then the absolute value is just \sqrt{2} and the principle argument, \theta, is \pi/4 right? So then 1+i=\sqrt{2} e^{\pi i/4}. Now what do you get when you raise that expression to the fourth power?
And in general, when you have an expression z^n=-k, we obtain z=(-k)^{1/n} and
(-k)^{1/n}=k^{1/n}e^{i/n(\pi+2j\pi)}, \quad j=0,1,2,\cdots,n-1
Personally, I wouldn't bother with "polar form". The first part asks you to "Show that (1+i) is a root of the equation z^4=-4". That, alone, does NOT ask you to solve the equation. You can "show that 'a' is a root of the equation f(x)= b" by evaluating f(a) and showing that it is 'b'. Here, if z= 1+ i then z^2= (1+ i)^2= 1^2+ 2(1)(i)+ i^2= 1+ 2i- 1= 2i. Then z^4= ((1+ i)^2)^2= (2i)^2= -4.
You should also know that "if a+ bi is a root of a polynomial equation with real coefficients then the complex conjugate, a- bi is also a root". Having determined at 1+i is a root, we immediately know that 1- i is also a root. Knowing that 1+ i is a root, we know that z- (1+ i) is a factor of the polynomial z^4+ 4 and knowing that 1- i is a root, we know that z- (1- i) is a factor. That is, we can write z^4+ 4= (z- (1+i))(z- (1- i))P(x).
But (z- (1+i))(z- (1- i))= ((z- 1)- i)((z- 1)+ i)= (z- 1)^2- i^2= z^2- 2z+ 1- i^2= z^2- 2z+ 2 so that z^4+ 4= (z^2- 2z+ 2)P(z). Dividing z^4+ 4 by z^2- 2z+ 2 gives P(z)= z^2+ 2z+ 2. Use the quadratic formula to solve P(z)= z^2+ 2z+ 2= 0.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
