How Can I Solve for the Equilibrium Constants in These Equations?
The discussion focuses on calculating equilibrium constants from a set of five equations related to a chemical system. The user struggles with the algebraic manipulation required to derive these constants, specifically noting that the value of X is fixed at 200 and that K_{out} equals Cl_{out}. Participants highlight that the issue arises from having too many dependent equations, leading to trivial results like 0=0. The solution involves identifying and ignoring superfluous equations to isolate independent relationships necessary for calculating the equilibrium constants.
  • Understanding of equilibrium constants in chemical reactions
  • Familiarity with algebraic manipulation of linear equations
  • Knowledge of protein complex formation and non-cooperative binding
  • Ability to interpret and analyze chemical equations
  • Study the principles of chemical equilibrium and equilibrium constant calculations
  • Learn about linear dependence and independence in systems of equations
  • Explore protein chemistry, specifically complex formation and its impact on equilibrium
  • Review algebraic techniques for solving systems of equations
Chemistry students, researchers in biochemistry, and anyone involved in the study of chemical equilibria and protein interactions will benefit from this discussion.
Air
With the 5 equations, the equilibrium contants can be calculated at the bottom. (See image)
My complication
I am aware that X = 200 thus that value remains at that. Also, From the fourth equation K_{out} = Cl_{out}. But, I cannot seem to work out the values. If not simple algebra, what am I missing?
Won't hurt if you would explain what is the question that you are solving, at the moment you just posted a bunch of equations describing some undefined system.
From this, finding the concentrations at equilibrium.
I understand how the equations are set up but I can't seem to solve the maths to get the equilibrium constants. Is there something I am missing? Like I said, I am aware that X = 200 thus that value remains at that. Also, From the fourth equation K_{out} = Cl_{out}.
Simple algebra.
My bet is your problem is related to the fact you have too many equations - they are not all independent, which makes you getting 0=0 type result.
By equilibrium constants are we to guess that the protein forms complexes we might call XCl- and XCl2 in non-coperative fashion so it is characterised by a single equilibrium constant which it is required to calculate from the data?
I think you had better cite the entire question.
The whole question is posted in post number 3. https://www.physicsforums.com/showpost.php?p=4410136&postcount=3
You do realize there is no problem with solving the question using your approach and the simple algebra, it is just a matter of ignoring superfluous information?
When I substitute into each other, they all just cancel out to 0=0.
Which is exactly what I wrote in the post #5 - have you read it? That's because the linear equations are not independent. Ignore one of the linear ones and you will get the correct answer.
