Solving Final Temperature of Copper-Water Mixture
The final temperature of a copper-water mixture can be calculated using the heat exchange equation, which balances the heat lost by copper with the heat gained by water. In this case, a 150 g piece of copper at 90°C is mixed with 250 g of water at 20°C, resulting in a final temperature of approximately 23.7°C. The calculations show that minor discrepancies in rounding do not significantly affect the final result, and 23.7°C is an acceptable answer. Users confirm that plugging in the exact value of 23.6942°C yields a result close to zero in the heat exchange equation. Therefore, the solution is validated and considered correct.
sadifermi
I need help with a question. I think I have an answer, but don't know if it's right. It also doesn't add up to 0 if I plug in the final temperture into the equation. But I keep getting the same answer. Help please!
A 150 g piece of copper at 90°C is placed in 250 g of water at 20°C. Assume that no heat escapes into the surroundings. Find the final temperature of the mixture.
mass of copper: (0.150kg)
specific heat capacity: (390J/(kg°C))
temperture of copper: (t2-90°C)
mass of water: (0.250kg)
specific heat capacity: (4200J/(kg°C))
temperture of water: (t2-20°C))
equation: (mass of copper)(spec. heat cap.)(final temp - intial temp) + (mass of water)(spec. heat cap.)(final temp - initial temp) = 0
(0.150kg)(390J/(kg°C))(t2-90°C)+(0.250kg)(4200J/(kg°C))(t2-20°C))=0
1108.5t2=26265
t2 = 23.7°C
Heat Exchange of Copper and Water
1108.5t2=26265
t2 = 23.7°C
Correct solution!ehild
sadifermi said:
t2 = 23.7°C
It's just rounding error. If you plug in 23.6942 you'll get something close to 0. But don't change your answer to that. 23.7 C is fine.
Thanks! I appreciate it and the speedy reply!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
