Solving first and second order ODEs with Laplace transforms
109 replies · 13K views · last reply
TFM
Solve the following problems using Laplace Transforms:
[tex]y' - y = 2e^t, y_0 = 3[/tex]
[tex]y'' + 4y' + 4y = e^{-2t}, y_0 = 0, y_0' = 4[/tex]
[tex]y'' + y = sin(t), y_0 = 1, y_0' = 0[/tex]
[tex]y'' + y = sin(t), y_0 = 1, y_0' = -\frac{1}{2}[/tex]
N/A
I don't seem to understand how to use Laplace Transformation to solve ODE's! If anyone can help, I will be most grateful.
TFM
lets look at the first one: let L(F(t)) denote the laplace of F(t)
in general, you say that:
L(y'(t))-L(y(t))=L(2e^t) call this (1)
L(y(t))=y (in terms of s)
L(y'(t))=sL(y(t) - y(0) (This is one of the formulas from the table of laplace transforms)
=sy-3
so, substituting these back into (1): sy-3-y=2/(s-1) (also from the tables)
make y the subject, then you should get an expression for y in terms of s.
Then to find y(t) (which is what you are looking for), you must find the inverse of y.
I hope all is clear.
=sy-3
Where did the 'in terms of S' come from?
TFM
It might be confusing to use the same label y for the function und its Laplace transform. Better come up with a new letter like Y:smile:
You then have to solve (according to Sara)
[tex]sY(s)-3-Y(s)=\frac{2}{s-1}[/tex]
for Y(s) and find the inverse Laplace transform of this function.
Okay let's see if this makes sense:
you have the orginal equation, F(t)
[tex]y' - y = 2e^t[/tex]
then you make L(f(t)):
[tex]L(y'(t)) - L(y(t)) = L(2e^t)[/tex] ---(1)
I still can't see how you have gone from here to here:
TFM
that is not from one step to another.
L(y'(t))-L(y(t))=L(2e^t) this is something
and
L(y(t))=Y is something else.
In other words, LET L(y(t))=Y
so therefore, L(y'(t))=sY-3
Let's see then...:
[tex]L(F(t): L(y'(t)) - L(y(t)) = L(2e^t)[/tex] ---(1)
and also:
[tex]L(y(t)) = Y[/tex]
so inserting into (1)
[tex]L(F(t): L(y'(t)) - Y = L(2e^t)[/tex]
[tex]L(y'(t)) = Y + L(2e^t)[/tex]
I see now where the 3 comes from, [tex]y_0 = 3[/tex]
[tex]L(y'(t)) = Y - y_0[/tex]
[tex]L(y'(t)) = Y - 3[/tex]
substitute back into (1):
[tex]Y - 3 - L(y(t)) = L(2e^t)[/tex]
does this look right so far?
TFM
you made a small mistake,
L(y'(t))=sY-3
because you must use the formula:
L(F'(t))=sL(F(t))-F(0)
Im not sure but I think you are expected to know this general formula.
so this gives:
sY-3-L(y(t))=L(2e^t)
Yes, the formula:
[tex]L(F(t)) = sL(F(t)) - F(0)[/tex]
looks useful. I assume the [tex]sL(F(t))[/tex] is inequivalent to: [tex]s*L(y(t)) = Y[/tex]
so:
[tex]L(y'(t)) = sY - 3[/tex]
putting back into (1)
[tex]sY - 3 - sY - 3 = L(2e^t)[/tex]
does this look right?
TFM
The star means convolution (in Laplace language) so it is inequivalent
You have:
L(y'(t))-L(y(t))=L(2e^t) this is (1)
we said let L(y(t))=Y
and then we know that L(y'(t))=sY-3
so putting into (1) gives:
sY-3-Y=L(2e^t)
Why are you putting sY-3 twice?
You have:
sY-3-Y=L(2e^t)
I meant the star as in times, Sorry.
I am not sure, how am I putting in sY-3 twice? sY-3-Y=L(2e^t) only has sY - 3 in once?
TFM
exactly so again you have to remember:
(A) we said let L(y(t))=Y
(B) and then we know that L(y'(t))=sY-3
(C) sY-3-Y=L(2e^t)
These are the three main steps that should give you the equation of Y in terms of s.
So, what would you do next?
Well, judging from your first post, rearrange into Y?
so this would be:
[tex]sY-3-Y=L(2e^t)[/tex]
put 3 to one side:
[tex]sY-Y=L(2e^t) + 3[/tex]
factorise out Y:
[tex]Y(s - 1) = L(2e^t) + 3[/tex]
divide by (s - 1):
[tex]Y = \frac{L(2e^t) + 3}{s - 1}[/tex]
Does this look right?
TFM
no, before you 'put to one side' on your second step, you have to find the laplace of
2e^t
sY-3-Y=L(2e^t)
so,
sY-3-Y=2/(s-1)
(do you know that L(2e^t)=2/(s-1) ?)
now, you make Y the subject.
I have a table with Laplace conversions, and it gives:
[tex]e^{-\alpha t} = \frac{1}{p + \alpha}[/tex]
so
[tex]2e^{t} = \frac{2}{p + t}[/tex]
I'm assuming p and s are equivilant
so now:
[tex]sY-3-Y = L(2e^t)[/tex]
[tex]sY-3-Y = \frac{2}{s + t}[/tex]
now take over the 3:
[tex]sY-Y = \frac{2}{s + t} + 3[/tex]
factorise Y:
[tex]Y(s - 1) = \frac{2}{s + t} + 3[/tex]
thus giving Y
[tex]Y = \frac{\frac{2}{s + t} + 3}{s - 1}[/tex]
Does this look better?
TFM
e^(-at)=1/(s-a)
so: (the right hand side is the laplace so it has nothing to do with t)
2e^(t)=1/(s+1) (since in our case, -a=1)
Now, make Y the subject from:
sY-3-Y=1/(s+1) (do you agree?)
I feel slightly sill, I meant to do that, but didn't :redface:
So:
[tex]sY-3-Y = \frac{2}{s + 1}[/tex]
now:
[tex]sY-Y = \frac{2}{s + 1} + 3[/tex]
[tex]Y(s - 1) = \frac{2}{s + 1} + 3[/tex]
[tex]Y = \frac{\frac{2}{s + 1} + 3}{s - 1}[/tex]
Is this right?
TFM
Im sorry, i misread; the L(2e^t) means that our a=1 so that means L(2e^t)=2/(s-1)
not 2/(s+1)
but your steps are correct and so your Y would be:
sY-3-Y=2/(s-1)
Y(s-1)=2/(s-1) +3
so Y=2/(s-1)^2 + 3/(s-1) (by dividing both sides by s-1)
is this clear?
so, what would you do next?
so:
[tex]Y = \frac{\frac{2}{s - 1} + 3}{s - 1}[/tex]
is the same as:
[tex]Y = \frac{2}{(s - 1)^2}+\frac{3}{s - 1}[/tex]
so now, from your first post again, I need to find the inverse:
thus:
[tex]\frac{1}{Y} = \frac{(s - 1)^2}{2}+\frac{s - 1}{3}[/tex]
TFM
no, carefull... when i say inverse i don't mean 1/Y;
Y=2/(s-1)^2 + 3/(s-1) call this (2) (This is you Laplace of the function you are looking for)
So you want to find the function in terms of t that would give you (2) when you find its laplace. so you want to find a function of t.
so, Y(t)= something that when you find its laplace you would get (2)
so, first, what is the function in terms of t that when you find its laplace you would get 2/(s-1)^2 ? (you would need to use your tables)
The closest I can find is:
[tex]\frac{e^{-at}-e^{-bt}}{b - a} = \frac{1}{(p + a)(p + b)}[/tex]
or
[tex]\frac{ae^{-at}-be^{-bt}}{b - a} = \frac{p}{(p + a)(p + b)}[/tex]
TFM
ok, let's first look at: 3/(s-1) since it's simpler:
L(e^t)= 1/(s-1) as we saw before
so to get 3/(s-1) this means the function is 3e^t
yes?
Yes, that makes sense and agrees with the similar one in the table.
TFM
ok, so now what is the inverse of 2/(s-1)^2 ?
You have to use the first shift theorem which should be on the tables.
Would it not be:
[tex]2 \frac{1}{(p + a)(p + b)}[/tex]
with a and b both minus 1 giving:
[tex]\frac{2}{(p - 1)(p - 1)}[/tex]
TFM
when you find the function, it should be in terms of t. eg:
inverse laplace of 3/(p-1) is 3e^t (from tables) (in terms of t's no p's; the p's are only in the laplace not the inerse of the laplace.
inverse laplace of 2/(p-1)^2 is...? find from tables, do you know the first shift theorem?
Its not on the table, and I can't seem to find it in my notes...
TFM
Ok, the first shift theorem says that:
if you have a function that looks like: e^(at)F(t);
the laplace of that is the laplace of F(t) but instead of putting p, you put p-a
eg: L(e^3t(t))
we know that laplace of t is 1/p^2 (you know that from the tables right?)
and so here a=3 so the laplace of e^(3t)(t)=1/(p-3)^2
so, where ever you have p, you replace with p-a in this case, p-3
Do you agree??
so could you now find the inverse of 2/(s-1)^2
do have any ideas?
Thus bit is right?:
[tex]\frac{3}{(p-1)} : 3e^t[/tex]
okay. so now I have to use first shift theorem on:
[tex]2/(p-1)^2[/tex]
Would this not give:
[tex]2/((p - 3)-1)^2[/tex]
I think that bit is wrong though?
Also, my table doesn't have t on its own, but I will accept that t goes to 1/p^2
TFM
your table has t^n so just say that n is one to give laplace is 1/p^2
so, for 2/(p-1)^2
why did you do this: 2/((p-3)-1)^2 ?
You have to find a function in t such that when you find the laplace of it, you would get 2/(p-1)^2. So, don't apply the first shift theorem on it, you have to unapply the first shift theorem...does that make sense?
Hint: what is the laplace of 2t ? (using tables with n=1)
