Solving for Angular Acceleration & Speed of Rod in Freefall
The problem involves a uniform rod of mass 12kg and length 1.0m, pivoted at one end and falling from a vertical position. Participants are tasked with determining the angular acceleration as the rod passes through the horizontal and the angular speed as it passes through the vertical.
  • Exploratory, Assumption checking
  • Participants explore the relationship between potential energy and kinetic energy, questioning the use of the rod's length as its height. There are attempts to calculate angular acceleration and speed using different equations, with some participants expressing uncertainty about the assumptions made regarding angular acceleration.
Some participants have provided guidance on the need to consider the center of mass when calculating torque. There is an ongoing exploration of the correct point of application for the force and the corresponding distance to the pivot, with multiple interpretations being discussed.
Participants are navigating the complexities of angular motion, particularly the implications of varying angular acceleration and the correct application of torque equations. There is a focus on understanding the physical setup and the assumptions that underpin the calculations.
Juniper7
Consider a uniform rod of mass 12kg and length 1.0m. At its end, the rod is attached to a fixed, friction-free pivot. Initially the rod is balanced vertically above the pivot and begins to fall (from rest) as shown in the diagram. Determine,
a) the angular acceleration of the rod as it passes through the horizontal at B.
b) the angular speed of the rod as it passes through the vertical at C.
PE = mgh
KE = 1/2Iω2
Irod = 1/3ml2
ω2 = ωo2 + 2αθ
a) PE = KE
mgh = 1/2Iω2
(12kg)(9.81m/s2)(1.0m) = (0.5)(1/3)(12kg)(1.0m)ω2
ω = 7.668rad/s
Can I use the length of the rod as its height?
ω2 = ωo2 + 2αθ
(7.668)2 = 2α90° (90° = 1.571rad)
α = 18.7rad/s2
is that right?
b) ω2 = ωo2 + 2αθ
ω2 = (7.668rad/s)2 + 2(18.7rad/s2)(1.571rad)
assumptions: the α will stay the same and I'm trying to calculate from point B to C so θ = 90°
ω = 10.84rad/s
Thanks in advance!
Use the center of mass of the rod.
Juniper7 said:
a) PE = KE
mgh = 1/2Iω2
ω = 7.668rad/s
ω2 = ωo2 + 2αθ
α = 18.7rad/s2
is that right?
b) ω2 = ωo2 + 2αθ
ω = 10.84rad/s
This is incorrect .
The relation in red is applicable when the angular acceleration is constant which is not the case in this problem.
Write torque equation for the rod when it is horizontal.
Tanya Sharma said:
This is incorrect .
Ok, so:
τ = Iα
τ = 1/3ml2α
τ = rF
F = mg
τ = rmg
rmg = 1/3ml2α
(1.0m)(12kg)(9.81m/s2) = (1/3)(12kg)(1m)2α
α = 29.4rad/s2
This seems rather high...
would the radius of the rod be its length because it is pivoting on its end? I think i did something wrong... thanks for the help
1) What is the point of application of the force mg which is producing the torque about the pivot ?
2) What is the distance between this point of application and the pivot ?
1) Would that be at the end of the rod, the opposite end of the pivot?
2) if the point of application is the end, then it would be 1.0 m and the radius should be 1.0m, right?
No.
Where does weight of a body act ?
Tanya Sharma said:
No.
Oh, the centre of mass? so the radius would be half of the length, 0.5m, right?
Correct.
Thank you!
  • · Replies 20 ·
  • · Replies 21 ·
