Solving for Electrical Potential Energy: Durcell's Example
11 replies · 3K views
cwill53
What is the potential energy of an arrangement of eight negative charges on the corners of a cube of side b, with a positive charge in the center of the cube? Suppose each negative charge
is an electron with charge −e, while the central particle carries a double positive
charge, 2e?
$$U=\frac{1}{2}\sum_{j=1}^{N}\sum_{k=j}^{}\frac{1}{4\pi \epsilon _{0}}\frac{q_{j}q_{k}}{r_{jk}}$$
This question is an example in Durcell's Electricity and Magnetism.
The solution goes as follows:
[In this case] there are four different types of pairs. One type involves the center charge, while the other three involve the various edges and diagonals of the cube. Summing over all pairs yields
$$U=\frac{1}{4\pi \epsilon _0}(8\cdot \frac{(-2e^2)}{(\frac{\sqrt{3}}{2})b}+12\cdot \frac{e^2}{b}+12\cdot \frac{e^2}{\sqrt{2}b}+4\cdot \frac{e^2}{\sqrt{3}b})$$
Then the book introduces the following equation to sum over pairs
I'm just a bit confused at the meaning of finding the electrical potential energy. Can someone explain what these equations mean intuitively and then how to apply the equation to the above example? Thanks.
cwill53 said:
Homework Statement:: What is the potential energy of an arrangement of eight negative charges on the corners of a cube of side b, with a positive charge in the center of the cube? Suppose each negative charge
charge, 2e?
Relevant Equations:: $$U=\frac{1}{2}\sum_{j=1}^{N}\sum_{k=j}^{}\frac{1}{4\pi \epsilon _{0}}\frac{q_{j}q_{k}}{r_{jk}}$$
$$U=\sum_{j=1}^{N}\sum_{k=j}^{}\frac{1}{4\pi \epsilon _{0}}\frac{q_{j}q_{k}}{r_{jk}}$$
The process here is to figure how much energy must be put into assemble these charges. You can figure the total energy as the pairwise energy sum of all the constituent particles Each pair is counted only once and the total might be negative.
That being said the sum over pairs I would write as $$U=\sum_{j=1}^{N}\sum_{k=j+1}^{N}\frac{1}{4\pi \epsilon _{0}}\frac{q_{j}q_{k}}{r_{jk}}$$ Your method (I think) counts everything twice and divides by 2...
The book method just segregates the sum into sets of pairs the same distance apart for convenience in calculating. (So write out the terms in the sum and see the equivalence!).
Just to point out that the inner sum in the OP should be over ##k \neq j##, not ##k = j##.
I was just getting ready to correct it, thanks. I still don’t understand what that part means.
That the inner sum sums over all possible values of ##k## except ##j##. The double sum therefore sums over all possible combinations of ##j## and ##k## such that ##j## and ##k## are distinct. However, j=1 and k=2 represents the same pair of charges as j=2 and k=1 and so on. The potential energy of each pair is therefore counted twice, which is the reason for the factor of 1/2 in front.
So is the inner sum as to avoid counting the pairs more than two times?
No, it is a double sum because we are considering pairs. For each charge j=r in the outer sum we add up all the potential energies to which it contributes as a member of a pair, so the inner sum runs over all those partners, i.e. all except r.
But each pair (r,s) will get counted twice, once as j=r, k=s and again as j=s, k=r, so we halve the total.
It might be clearer if the sum were written ##\Sigma_j\Sigma_{k>j}##, avoiding the double counting.
I’m sorry, but I’m really having trouble understanding how to apply this equation to this problem for some reason. I’ll write out an example of how I think I’m supposed do it, it would be great if you can correct where I go wrong.
Is it that I do the following summation, taking j=1,2,...,N but for every time I take a summation of j=N, ##N\in ##{1,2,3,4,5,6,7,8,9} (for the nine charges including the charge of +2e), k is NOT equal to j? In this sense, would I be taking j and summing over k a total of 8 different times for every k, since k isn't equal to j? For the first set where j=1 I would have addend of U, being
$$U_1=\frac{1}{2}\frac{1}{4\pi \epsilon _0}((\frac{q_{1}q_{2}}{r_{12}}+\frac{q_{1}q_{3}}{r_{13}}+\frac{q_{1}q_{4}}{r_{14}}+\frac{q_{1}q_{5}}{r_{15}}+\frac{q_{1}q_{6}}{r_{16}}+\frac{q_{1}q_{7}}{r_{17}}+\frac{q_{1}q_{8}}{r_{18}}+\frac{q_{1}q_{9}}{r_{19}}))$$
Then the second addend would be
$$U_2=\frac{1}{2}\frac{1}{4\pi \epsilon _0}((\frac{q_{2}q_{1}}{r_{21}}+\frac{q_{2}q_{3}}{r_{23}}+\frac{q_{2}q_{4}}{r_{24}}+\frac{q_{2}q_{5}}{r_{25}}+\frac{q_{2}q_{6}}{r_{26}}+\frac{q_{2}q_{7}}{r_{27}}+\frac{q_{2}q_{8}}{r_{28}}+\frac{q_{2}q_{9}}{r_{29}}))$$
The third addend would be
$$U_3=\frac{1}{2}\frac{1}{4\pi \epsilon _0}((\frac{q_{3}q_{1}}{r_{31}}+\frac{q_{3}q_{2}}{r_{32}}+\frac{q_{3}q_{4}}{r_{34}}+\frac{q_{3}q_{5}}{r_{35}}+\frac{q_{3}q_{6}}{r_{36}}+\frac{q_{3}q_{7}}{r_{37}}+\frac{q_{3}q_{8}}{r_{38}}+\frac{q_{3}q_{9}}{r_{39}}))$$
and so on, making
$$U_{TOT}=U_1+U_2+U_3+...+U_N, N=9$$
Is this correct?
and so on, making
Is this correct?
Yes, and note that you have ##q_1q_2## in one sum and ##q_2q_1## in another, hence the need to halve the total.
My goodness, all that TeX I had to edit because I put in double subscripts initially for everything!
I see it now. Thanks a lot. I'm just glad I can understand it now.
Which is why I recommended the "triangular" sum in post #2!...same result... .
