Solving for matrix A when only A^{-1} is known
  • Thread starter Saladsamurai
19 replies · 3K views · last reply
Saladsamurai
Given
[tex]A^{-1} =<br /> \left[\begin{array} {cc}<br /> 2&-1\\<br /> 3&5<br /> \end{array}\right][/tex]
find A.
The only thing that we have learned regarding inverses so far is that for a 2x2 matrix, the inverse is given by
[tex]A^{-1} = \frac{1}{ad-bc}<br /> \left[\begin{array} {cc}<br /> d&-b\\<br /> -c&a<br /> \end{array}\right][/tex]
So I set corresponding entries equal to each other and got the following 4 EQs:
[tex]a = \frac12-\frac{bc}{d}[/tex]
[tex]c = \frac{ad}{b}-1[/tex]
[tex]b = \frac13+\frac{ad}{b}[/tex]
[tex]d = \frac15 +\frac{ad}{c}[/tex]
So my question is, what is the best way to solve these? I have been trying substitution, but I guess I really don't know how to use that method with so many EQs?
I feel like I am just running in circles here! I took the 1st EQ and plugged the 2nd in for 'c' then I plugged the 3rd in for 'b' and the 4th for 'd.'
But that did not eliminate anything. I still have all 4 vars in the final EQ.
I need something more systematic. I am not sure which moves are legal here. How can eliminate something here?
No no, for 2x2, a,b,c,d are the entries in the actual matrix A. a = 2, b = -1, c = 3, d = 5.
Sorry. I don't follow. I know that a,b,c,d are the entries in A. But I am given the entries in A-1. So I need to work backwards, right?
Thanks.
EDIT: I think that I see what you mean. I did that; I am just showing the final forms of my EQS.
For example the 1st EQ comes from d/(ad-bc) = 2
Oh wait! I didnt see you were given the inverse and need to find A. Hmm let me think about this.
Uh, (A^(-1))^(-1)=A, right? Just invert A^(-1) to find A.
Oh. I guess that would be a lot easier!
But while you are here: do you see what I mean about the endless loop of substitutions if I were to use that method?
Is there a better way to solve this system? I thought about using Gaussian Elim, but for some reason my gut is against it.
No, I don't see any problems with endless loops of substitution. You seem to be using the same a,b,c,d notation for the entries of A as for A^(-1), if A^(-1)_11 is 'a' then A_11 probably shouldn't also be denoted by 'a'. Just invert A^(-1) to get A. Period. That's an order. In the world of invertible matrices there is no distinction between "matrices" and "inverse matrices". They all use the same formulas.
Okay! I will! BUT ( I don't expect you to read this, 'cause I know how that goes) I don't think that I abused any notation here.
If
[tex]A =<br /> \left[\begin{array} {cc}<br /> a&b\\<br /> c&d<br /> \end{array}\right][/tex]
then,
[tex] A^{-1} = \frac{1}{ad-bc}<br /> \left[\begin{array} {cc}<br /> d&-b\\<br /> -c&a<br /> \end{array}\right]<br /> =\left[\begin{array} {cc}<br /> 2&-1\\<br /> 3&5<br /> \end{array}\right][/tex]
Set corresponding entries equal and you get for example
[tex]\frac{1}{ad-bc}*d=2\Rightarrow a = \frac12-\frac{bc}{d}[/tex]
which is what I got in the first post so and so forth.
So I believe that my EQs are correct and therefore I do see a problem with nasty substitutions.
Maybe you are a substitution wizard. I am not.
The problem is that you never eliminated any of the variables. You eliminated the 'c' from the first equation by using the second equation to make a substitution. But because you did not eliminate 'c' from the third and fourth equations, it reappeared later in your calculation.
Exactly! SO can I use Gaussian elimination? I just feel weird about it since I have a's times b's and so and so forth.
That's like having x1*x2 in GE and I have yet to come upon that. Is GE still a valid solution for problems involving variables with other variables as coefficients?
Thanks :smile:
It's not Gaussian elimination.
But yes, you can solve this system of equations by systematically eliminating variables through substitution.
This is a slow and painful way of finding the inverse of A-1, but you can do it.
Painful. Yes, I have noticed. So would it be safe to say that if I choose to start with the 1st EQ:
and then start substituting EQS 2,3 & 4, I can use 2,3, & 4 as many times as needed to eliminate all of the variables?
I just cannot reuse EQ 1 again.
Or is that not a safe assumption?
(I know that Dick's way is the "best" way. But sometimes I like to do it the 'hard' way. I learn more that way)
Well, I suspect you have the right idea -- but can't be sure. (it's easy enough for you to test yourself :wink:)
The "can't reuse" bit isn't that it's mathematically unsound to do so -- it's that it merely acts contrary to the way you're simplifying the system of equations.
Incidentally, Gaussian elimination can be used to find the inverse of a matrix T. Presumably you've seen the algorithm in your book? It involves creating the augmented matrix
[T | I]​
and then row reducing.
easy yes. but still painfully time consuming.
Yeah. I just know that in order to eliminate a variable, the equations have to be linearly independent of one another.
So if the whole reusing of EQs gets really confusing for me.
My original approach was the following:
1. Use EQ 1 which is solved for 'a'
2. plug EQ 2 into 1 where ever I see 'c'
3. plug EQ 3 into the resultant of the above where ever I see 'b'
4. plug EQ 4 into the resultant of the above where ever I see 'd'
rinse and repeat steps 2 - 4 until all variables are gone except for 'a.'
It just got to the point, though, that I wasn't sure if that would actually ever happen!
Will it? Or could it be that there is a unique sequence in which I would have to substitute the EQs in order to successfully solve for 'a' alone?
[T | I]​
Not there yet. But I peaked ahead a little and that does look familiar.
Thanks!
And the problem you saw is that when you eliminated 'b' from equation 1, you used a substitution that introduced 'c', which undid your earlier work to eliminate 'b' from equation 1.
What you need, then, is a substitution that eliminates 'b', but doesn't have any occurrences of 'c'.
Re Gaussian elimination...
C'mon, this is just a 2 x 2 matrix! How painfully time consuming can that be?
This comment was regarding using substitution
method using the 4 EQs in post #1, not GE.
So if you would really like to know, give it a try :wink:
As an aside, even if GE were employed, it still wouldn't be
a 2x2 matrix as you say. I think maybe you misunderstood
the thread.
Mark44 said:
My comment pertained to the 2x2 matix in post #1, and using GE to solve the 2x4 matrix system [A-1|I] to get [I|A].
I see. The way that you snipped my quote though made it seem like when I said it was "painfully time consuming" I was speaking solving [A|I]. But I was not.
In post #12 I decided that I would like to further prod the idea of using substitution with the 4 EQs in post #1.
It gets pretty nasty as pointed out by Hurkyl. I am still curious to know if there is only one exact sequence that the EQs must be substituted in in order to reduce the EQs to 1 in 1 unknown. Though I doubt there is only one, I have yet to one. But that is because I went to bed. But now I am up at at 'em :smile:
Hopefully I won't spend all afternoon on this silly idea and will actually make some progress in the text :smile:
But I like exploring... so if I do, that's cool too.
