Solving Force and Velocity: Get Answer in 7.3m/s
  • Thread starter Thread starter brentwoodbc
    Force Velocity
The discussion focuses on solving a physics problem involving force, velocity, and energy conservation. The initial calculations using the formula f=ma and kinematic equations lead to an incorrect final velocity of 16 m/s, while the correct answer is 7.3 m/s. Participants emphasize the importance of understanding initial conditions, specifically whether the initial velocity is zero, and the role of gravitational potential energy (Ep) and kinetic energy (Ek) in the total energy equation. They clarify that total energy is conserved throughout the motion, allowing for calculations at different points. The conversation concludes with a reinforcement of using energy conservation principles to find the total energy at various stages of the problem.
brentwoodbc
I did
f=ma
(30+20)/2=2a
a=12.5m/s^2
vf^2=vi^2+2ad
vf^2=0+2•12.5•10
vf= 16 m/s
I remember doing a question like this on a test a while ago and I think the teacher said you don't know that the initial velocity is 0 or something like that?
anyways my way I don't get the right answer, the correct answer is 7.3m/s
How do I do this?
The area under the graph gives the total work done.
At 10m, the box will have two kinds of energy, one is kinetic, what is the other?
ya there is ep and ek but you can't really find Ek at the start or at the end right?
unless you assume the starting velocity is 0 but what if its not?
or do u use 250j total energy and the inititial Ep, I thinks that's right.
That's the nice thing about conservation of energy.
Ep+Ek= Total energy up to the point of the motion.
So at the beginning
mghinitial+1/2mv2initial = Total energy.
And at any other point
mgh + 1/2 mv2= Total energy at that point.
So if you want the energy at the end. You can get the total energy there using the area.
so mghend +1/2mv2end=Total energy at the end.
thank you very much.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
