Solving Integral with Logarithm Identity
8 replies · 2K views
parton
I read the following expression in a book:
[tex]\int_{-\infty}^{\infty} \dfrac{1}{t(1-t)} \log \left| \dfrac{t^{2} q^{2}}{(p-tq)^{2}} \right| ~ dt = - \pi^{2}[/tex]
p and q are both timelike four-vectors, so p², q² > 0
This integral was solved by using the identity
[tex]\lim_{s \to \infty} \int_{-s}^{s} \dfrac{\log \vert t-a \vert}{t-b} ~ dt = \dfrac{\pi^{2}}{2} sign(b - a)[/tex]
But I don't know how I can apply this identity to the integral above. I don't find any substitution or anything else to 'convert' the integral
in such a shape where I can use these formula.
Could anyone help me please?
Hi parton! :smile:
Try splitting the 1/t(1-t) in particle fractions, and the log into the difference of two logs, and then apply the identity several times. :wink:
Hi tiny-tim ! Thanks for your answer :smile:
I tried to split the integral as you suggested:
[tex]\int_{-\infty}^{\infty} \dfrac{1}{t(1-t)} \log \left| \dfrac{t^{2} q^{2}}{(p-tq)^{2}} \right| ~ dt = \int_{-\infty}^{\infty} \left[ \dfrac{1}{t} - \dfrac{1}{t-1} \right] \left[ \log \vert t^{2} q^{2} \vert - \log \vert (p-tq)^{2} \vert \right] ~ dt[/tex]
For the first part, I've got:
[tex]\int_{-\infty}^{\infty} \left[ \dfrac{1}{t} - \dfrac{1}{t-1} \right] \log \vert t^{2} q^{2} \vert \right] ~ dt= - \pi^{2}[/tex]
Here, I decomposed the logarithm again, i.e.
[tex]\log \vert t^{2} q^{2} \vert^{2} = 2 \log \vert t \vert + \log \vert q^{2} \vert[/tex]
I just used the identity for computing
[tex]- 2 \int_{-\infty}^{\infty} \dfrac{1}{t-1} \log \vert t \vert = - \pi^{2}[/tex]
The other integrals coming from this part will vanish, for example:
[tex]2 \int_{-\infty}^{\infty} \dfrac{1}{t} \log \vert t \vert ~ dt = \left[ \log \left( \vert t \vert \right) ^{2} \right]_{-\infty}^{\infty} = 0[/tex]
I argued that: [tex]\left[ \log \left( \vert t \vert \right) ^{2} \right]_{-s}^{s} = 0[/tex], so it has also to be valid for s--> infinity. But I'm not sure wheter this argument is correct.
Nevertheless, I don't know how to compute the second part of the originial integral:
[tex]- \int_{-\infty}^{\infty} \left[ \dfrac{1}{t} - \dfrac{1}{t-1} \right] \log \vert (p-tq)^{2} \vert ~ dt[/tex]
There is this nasty square appearing in the logarithm, and now I don't know how to continue :confused:
To you know some way to solve this?
Don't you know something about log xe?
ok, maybe I could simply write:
[tex]-\int_{-\infty}^{\infty} \left[ \dfrac{1}{t} - \dfrac{1}{t-1} \right] \log \vert (p-tq)^{2} \vert ~ dt = -2 \int_{-\infty}^{\infty} \left[ \dfrac{1}{t} - \dfrac{1}{t-1} \right] \log \vert p -t q \vert ~ dt[/tex]
But how do I solve that? p and q are four-vectors, so I can't simply apply a substitution !?
Hi parton! :wink:
The difficulty is that p and q are 4-vectors.
But (p - tq)2 is a quadratic in t (with coefficients which are combinations of the coordinates of p and q), so it must be of the form (t - a)(t - b), where (p - aq)2 = (p - bq)2 = 0.
Does that help? :smile:
Yes, it does help, thanks a lot :smile:
So, I wrote:
[tex](p-tq)^{2} = (t-t_{1}) (t-t_{2})[/tex]
where [tex]t_{1,2} = \dfrac{1}{q^{2}} \left[ pq \pm \sqrt{ (pq)^{2} - p^{2} q^{2} } \right][/tex]
And I've got:
[tex]- \int_{-\infty}^{\infty} \dfrac{1}{t} \left[ \log \vert t - t_{1} \vert + \log \vert t - t_{2} \vert \right] = - \dfrac{\pi^{2}}{2} \left[ sign(-t_{1}) + sign(-t_{2}) \right] = 0[/tex]
This is of course equal to zero, because of the opposite signs of [tex]t_{1}[/tex] and [tex]t_{2}[/tex].
But the next one isn't so easy:
[tex]+ \int_{-\infty}^{\infty} \dfrac{1}{t-1} \left[ \log \vert t - t_{1} \vert + \log \vert t - t_{2} \vert \right] = \dfrac{\pi^{2}}{2} \left[ sign(1-t_{1}) + sign(1-t_{2}) \right][/tex]
Ok, I know that if [tex]t_{2} < 0 \Rightarrow 1-t_{2} >0 \Rightarrow sign(1-t_{2}) = 1[/tex]
But what is [tex]sign(1-t_{1})[/tex] ?
sorry, I made a mistake.
The equation above is not equal to zero.
If I choose a frame where [tex]p = (p_{0}, \vec{0})[/tex] than I have:
[tex]t_{1,2} = \dfrac{p_{0}}{q^{2}} \left[ q^{0} \pm \vert \vec{q} \vert \right] < 0[/tex] because of [tex]q^{2} = q_{0}^{2} - \vec{q} \, ^{2} > 0[/tex] and [tex]q_{0} < 0[/tex].
So I obtain:
[tex]- \int_{-\infty}^{\infty} \dfrac{1}{t} \left[ \log \vert t - t_{1} \vert + \log \vert t - t_{2} \vert \right] ~ dt = - \dfrac{\pi^{2}}{2} \left[ sign(-t_{1}) + sign(-t_{2}) \right] = - \pi^{2}[/tex]
and
[tex]+ \int_{-\infty}^{\infty} \dfrac{1}{t-1} \left[ \log \vert t - t_{1} \vert + \log \vert t - t_{2} \vert \right] ~ dt = \dfrac{\pi^{2}}{2} \left[ sign(1-t_{1}) + sign(1-t_{2}) \right] = \pi^{2}[/tex]
and finally:
[tex]-\int_{-\infty}^{\infty} \left[ \dfrac{1}{t} - \dfrac{1}{t-1} \right] \log \vert (p-tq)^{2} \vert ~ dt = 0[/tex]
Is anything wrong in my argumentation or is it correct?
By the way,
does anyone know where I can find such identities like
Is there any book where such formulas are "collected"? I looked in different tables of integrals, but couldn't find them.
