Solving Integrals Involving Square Roots
  • Thread starter Thread starter transgalactic
    Integral
10 replies · 2K views
transgalactic
[tex] \int \frac{r^2dr}{\sqrt{r^2+x^2}}=\int{rdt}\\[/tex]
[tex] t=\sqrt{r^2+x^2}\\[/tex]
[tex] dt=\frac{2rdr}{2\sqrt{r^2+x^2}}[/tex]
i tried to solve it like that
If you do it like that the r^2 in the numerator will pose a problem. Try the substitution [itex]r=x \sinh u[/itex].
No, it would be [tex] \int \frac{r^2dr}{\sqrt{r^2+x^2}}=\int{\sqrt{t^2 - x^2}dt}\\[/tex]
Cyosis said:
If you do it like that the r^2 in the numerator will pose a problem. Try the substitution [itex]r=x \sinh x[/itex].
erm :redface: … xsinhu :wink:
what do i do after
whats the substitution
and i don't know hyperbolic stuff
its not on the course
That integral has a sign ambiguity, because if [itex]t=\sqrt{r^2+x^2}[/itex] then [itex]r=\pm \sqrt{t^2-x^2}[/itex]. Which one do you take?
Do you know of a good substitution if the integrand had been [itex]\sqrt{1-x^2}[/itex]? Try to find a trigonometric substitution for which 1-(...)^2=(...)^2.
there is no trigonometric substitution for it
There is and it is the most famous trig identity at that. Any ideas?
tangence goes when there is no square root on the denominator
1/(x^2+1) type
so i don't have any clue
Tangent works fine for the square root case as well. But you're jumping in between integrals again. It will be helpful if you stick to one integral.
You speak with considerable authority here, but it is unwarranted. Draw a right triangle with the horizontal leg labelled x and the vertical leg labelled r and the hypotenuse labelled sqrt(r^2 + x^2). If the acute angle is labelled u, then sec u = sqrt(r^2 + x^2)/x and tan u = r/x, and sec u * du = dr/x.
