Solving Limits: How to Simplify \lim_{x->0}
  • Topic:
  • Thread starter Thread starter Petrus
    Limits Simplify
7 replies · 2K views
Petrus
Hello MHB,
I am currently working with a old exam and it says.$$\lim_{x->0}\frac{3-e^{x^2}-2\cos(x)}{x^2\sin^2(x)}$$
and this is how far I got but struggle on the simplify
Regards,
$$|\pi\rangle$$
Re: limit,taylor
I think you mean x goes to zero right ?
Re: limit,taylor
Yes ofcourse haha My bad..
Re: limit,taylor
$$\lim_{x \to 0}\frac{(3-1-x^2-\frac{x^4}{2!}-\cdot \cdot \cdot ) -2+x^2-2 \cdot \frac{x^4}{4!} +\cdot \cdot \cdot }{x^3-\frac{x^5}{3!}+\cdot \cdot \cdot}$$
Sounds like the numerator dominates, unless you meant sin^2(x) in the denominator ..
Re: limit,taylor
By the way , in the case of a limit we have to use the expansion of all functions near the point , which is approached by x , hence the functions must converge .
Re: limit,taylor
I am making so much typo..:( I did Edit it now!
Re: limit,taylor
I am sure you can solve it yourself :)
Re: limit,taylor
Actually I believe you are correct! I did accidently had a sign wrong.. If someone is interested how to solve it. You can first cancel out all $$x^0, 3-1-2$$ then you can also cancel out $$x^2, -x^2+\frac{2x^2}{2!}$$ expand that square function at numerator and divide evrything by $$x^4$$ and you get the answer $$- \frac{7}{12}$$, what I did wrong is that I did not see the negative sign in bracket at top. I did take $$\frac{1}{2}-\frac{2}{4!}$$ while it should be $$-\frac{1}{2}-\frac{2}{4!}$$
Thanks once again Zaid!:)
Regards,
$$|\pi\rangle$$
