Solving Logarithmic Equations: 2 Problems
  • Thread starter Thread starter 1/2"
    Logarithmic
This discussion focuses on solving two logarithmic equations: 1) log7(x3 + 27) + log7(x + 3) and 2) log5(51/x + 125) = log5(6) + 1 + 1/(2x). The first equation can be simplified using the properties of logarithms and the sum of cubes, leading to a quadratic equation. The second equation requires transforming the logarithmic expression into an exponential form to isolate x. Key insights include recognizing the need for proper parentheses and the importance of factoring.
  • Understanding of logarithmic properties and equations
  • Familiarity with exponential functions
  • Knowledge of factoring techniques, particularly the sum of cubes
  • Ability to manipulate algebraic expressions and equations
  • Study the properties of logarithms and their applications in solving equations
  • Learn about the sum of cubes and its factoring techniques
  • Practice solving cubic equations and their transformations
  • Explore exponential equations and their relationship with logarithmic forms
Students studying algebra, particularly those focusing on logarithmic and exponential functions, as well as educators seeking to clarify these concepts for their students.
1/2"
I have 2 problems ,which are:
1) Solve :log 7 (x 3+27) + log 7 (x+3)
2) Solve for x:log5 ( 5 1/x+ 125) log 5 6+1+1/2x
The first one tried like this :
log 7 { (x 3+27)/(x+3) }= 2
or 7 2 = (x 3+27)/(x+3)
But I don't know how to proceed beyond it please help!
in second one
log5{( 5 1/x+ 125) /6}=1+1/2x
but I can't proceed here too.
I need an urgent help!
Thank You!
Please check the original problems as I see typos abound. For instance, in the first problem,
...I see no right hand side. Also, if what you have above is correct, then you're next step...
...is already wrong. (Is is supposed to be divide?)
Finally, if the last step above is supposed to have a divide, then review factoring special products -- specifically, the sum of two cubes.
69
For the first one, you could multiply through by x+3 to give
49(x+3)=x^3+27
and then solve that cubic by simplifying and turning it into the form ax^3+bx^2+cx+d=0
but cubics are hard to solve, an easier way would be to realize that x^3+27 is a sum of two cubes, mainly x^3+3^3=(x+3)(x^2-3x+9) which means you can cancel the x+3 from the numerator and denominator, giving you only a quadratic to solve, which is much simpler. Remember to look back at the original question to figure out what the domain of x is.
For the second, do the same thing as you did above, turn the log into powers such that
\frac{5^{\frac{1}{x}}+125}{6}=5^{1+\frac{1}{2x}}
Now simplify the right hand side. You should be able to factorize out 51/x and then solve.
I agree with eumyang. Is the question to simply the above expressions? Also, with the second problem, are you missing any brackets/parenthesis at all?
The Bob
At least in the second, 1/2" specifically says "solve for x". There are no equations to be solved!
It's an honest mistake to mix up + and = considering they're the same key on the keyboard, but he did have lots of typos so it could have been re-interpreted as anything.
And for the first equation, let's just assume he started to solve the correct problem, i.e. f(x)=2.
Thanks for the help but I figured it out!
Thanks everyone!
  • · Replies 39 ·
  • · Replies 24 ·
