Solving MatLab "for" Loops With Vectors
The discussion focuses on solving a MatLab homework problem involving the evaluation of the function y(x) = x^2 - 3x + 2 for values of x between -1 and 3, using both "for" loops and vectorization. The initial attempt with a "for" loop fails to produce the correct graph due to the scalar nature of x, which leads to incorrect plotting. The correct approach involves using a vector for x and iterating through its elements, allowing for proper evaluation and plotting of the function.
  • Understanding of MatLab syntax and functions
  • Familiarity with vector operations in MatLab
  • Knowledge of plotting functions in MatLab
  • Basic understanding of polynomial functions
  • Learn about vectorization techniques in MatLab to improve code efficiency
  • Explore MatLab's plotting functions for better data visualization
  • Study the differences between scalar and vector operations in MatLab
  • Investigate optimization strategies for loops in MatLab
Students, educators, and professionals working with MatLab who are looking to optimize their coding practices and improve their understanding of vectorization versus iterative approaches.
sirclash
MatLab "for" loops
Write an m-file to evaluate y(x)= x^2 - 3x +2 for all values of x between -1 and 3, in steps of .1 . Do this twice, once with a for loop and once with vectors. Plot the resulting functions.
count=0;
for x= -1:.1:3
count = count+1;
y(count)= x.^2 -3*x +2;
end
plot(x,y)
z=-1:.1:3;
u= z.^2 -3*z + 2;
plot(z,u)
My vector is correct, however i have no clue why my "for" loop won't show the correct graph.
the problem is that x is a scalar, so you're plotting (3, {y_1,y_2,...y_n}) which makes no sense.
Instead, try this: plot(-1:.1:3,y)
also, inside your for loop, you don't need ".^". You can just use "^" since x is scalar there.
well, when you use the "for" part and say for x = -1:.1:3 . MATLAB only uses this for the loop. it does not make a vector out of it. well, i think it just keeps changing the value of x so that the value of x is the value for your last loop
try putting x = -1:.1:3 after your loop and keeping the plot(x,y)
sirclash, here check this code. It can clean up your code and make it a lot more efficient
Code:
%plot x, y
x= -1:.1:3;
for i=1:length(x)
y(i)= x(i)^2 -3*x(i) +2;
end
plot(x,y)
%plot z, u
z=-1:.1:3;
u= z.^2 -3*z + 2;
plot(z,u)
  • · Replies 32 ·
